Home made workshop tools - Page 15 - The Jockey Journal Board
Old 02-14-2014, 11:17 PM   #281
foureasy
foureasy's Avatar
Concrete guy, awesome idea and if you have the clamps, its so easy. I really need to go through this whole thread.
foureasy is offline   Reply With Quote
Old 03-06-2014, 12:57 PM   #282
Lester
Lester's Avatar
Here is a Home brew lathe tool that I had forgotten until the other day when I needed it again. Not in daily use but a good additon. This is a ball turning tool and it pretty easy to make. The frame is of Aluminium and I am turing Stainless 316 with out problems
Also note the brass handel on the tool.
Lester
'62 DuoGlide Mine for 25yrs
'62 Triumph T-Bird in boxes
'83 BMW R100 commuter
'80's couple of Jap chops too
Old 03-06-2014, 05:59 PM   #283
Stinky Pete
Stinky Pete's Avatar
Lester - that is a cool trick!
Geo - same goes for you! Can I come over to your house and shrink my smooth wassel fender?
Railing against the darkness.
My blog - http://garagebuilt.wordpress.com/
Stinky Pete is offline   Reply With Quote
Old 03-06-2014, 06:11 PM   #284
Stinky Pete,
For sure, shoot me a p.m. and we'll get together on it.
Old 03-11-2014, 03:30 PM   #285
knuckleworks
knuckleworks's Avatar
i have a small benchgrinder and only use it for small bits and shapening drillbits,it's modified to accept 5" flapdics on one side and has the fine stone for DB on the other,but i wanted it to be able to rotate and still stay in place on the lift table,well i found a new turn plate for fat tv's and bolted them togheter and to the table,an ecenterlock keeps it from swiveling in use
Lex Talionis
Old 03-11-2014, 04:18 PM   #286
That's the cat's pajamas....
Old 06-07-2014, 01:57 PM   #287
not a "big" tool but.... I had to make a gasket for the kicker cover. Had no punch for the holes, did the next best thing. Took a pneumatic tool adapter and a carbide tip and sharpened the inside of the inlet and punched clean holes...
Old 06-07-2014, 03:11 PM   #288
There you go ^^^^!
That's a good tip Rob.
You can make just about any size of gasket or leather punch you could ever want by sharpening either the outside or inside edge any tube or piece of pipe. Yours looks like its made from an air line fitting.
Old 06-08-2014, 08:16 AM   #289
mblab
Spent rifle casings work well for hole punches.
Mike
mblab is offline   Reply With Quote
Old 06-08-2014, 08:20 AM   #290
Mike
''Spent'' is the word here!!!....make sure the Primer is popped ! hahahahaha
Old 06-08-2014, 01:52 PM   #291
Sturdly
Sturdly's Avatar
Springer spring compressor. About $3 worth of 5/16 allthread, nuts, washers and pipe hanger strap. Doubled up the strap cause this new Chinese or Indian stuff is not much thicker than tinfoil. Pretty exciting listening to it creak and groan but it held even when tightening my forks with both upper and lower internal springs.
Sturdly is offline   Reply With Quote
Old 06-08-2014, 06:50 PM   #292
Ya, but with a live primer, you won't have to get the little plug out of the case.
Old 06-08-2014, 10:49 PM   #293
Great idea!
Old 06-08-2014, 10:58 PM   #294
Mike
Maybe a bit OT, but spent casings have some other values, too... modern-day Keihin carburetors do not have flathead idle mix screws - they are 'D' shaped. You can buy that expensive ass tool, or flatten one side of a .223 case and use it. I don't have a pic of mine, but one lives in the tool pouch of one of my bikes.
govmule84 is online now   Reply With Quote
Old 06-10-2014, 11:13 AM   #295
ELpolacko
ELpolacko's Avatar
I suppose I can qualify my tools as "Home Made" but probably stretching that line a bit.
My sheet metal tools:
My shrinker-stretcher stands, down to two of these right now.
My big fab table
Follow me: Website Facebook Instagram Photobucket
ELpolacko is offline   Reply With Quote
Old 06-10-2014, 11:24 AM   #296
ELpolacko
ELpolacko's Avatar
Adjustable engine stand I did for a Triumph Trident engine.
Helve Hammer:
Stamping dies to emboss sheet metal:
Collet wrench for my Pullmax:
Hard Tail Fixture:
Jug fixture to do cut new intake ports in VL jugs:
Old 06-10-2014, 12:05 PM   #297
Drake9
My big fab table
That table is awesome. What is the spacing on the holes and are they threaded? How thick is the table top?
Current Ride
81 Sportster Project
My Blog
http://bublitzbikes.blogspot.com/
Drake9 is offline   Reply With Quote
Old 06-10-2014, 12:09 PM   #298
ELpolacko
ELpolacko's Avatar
Table top is 5'X12' 1/2" thick and the holes are 1/2-13 threaded on 6" centers.
Eventually I want to replace the top with 3/4 or 1" plate with more holes. But this works very well for now.
Old 06-10-2014, 12:13 PM   #299
oilfield money
WOW it's just a dream for me
Old 06-10-2014, 01:37 PM   #300
I seen that gratuitous under hood shot of the truck.....thanks.
