37 Ford Wishbone for Frame!!!??? - The Jockey Journal Board
Old 09-13-2009, 09:32 PM   #1
TURBO RAT
Default 37 Ford Wishbone for Frame!!!???
I've had this idea to use a wishbone from a 37 ford car for a single downtube and top tube for a frame for a while. These are basically a thick walled tubing like ERW that carries a taper from about 3 and 1/2 inch oval shape down to circular about 1 inch in diameter. Has this been done? Good idea or will it get me killed? Seen people using the axles lately for the downtube and top tube, so I thought why not use the wishbone. Like taking old car parts and putting them to use.
Owner of SLAUGHTERHAUS FAB & REPAIR
I am bigd4xman on The HAMB
TURBO RAT is offline   Reply With Quote
Old 09-13-2009, 10:06 PM   #2
Default Re: 37 Ford Wishbone for Frame!!!???
they have been used as Harley springer fork tubes extensions for over 50 years, I've seen the welds where they are joined to the trees fail but not the wishbone itself.
Old 09-13-2009, 10:08 PM   #3
greasystain
please dont ruin a 37 bone.... send it to me and ill make you a piece of steel to match. k thanks.
greasystain is offline   Reply With Quote
Old 09-13-2009, 10:50 PM   #4
TURBO RAT
It's already "ruined" since I have already split it. I forgot about guys having used them as fork extensions on springers. Guess that means it would be stout enough for a frame. Think the taper would look bitchin since you can't get that look with plain tubing.
Old 09-14-2009, 09:51 AM   #5
Estaban
Estaban's Avatar
If the bone is in good shape it's more than strong enough..... Are you planning on drilling it as well? That could be a cool look
Estaban is offline   Reply With Quote
Old 09-14-2009, 10:37 AM   #6
Faust
Faust's Avatar
I'm not sure this is a radius rod or not, but it looks like it.
http://www.spartanframeworks.com/Bik.../EDR/EDR15.jpg
Faust is offline   Reply With Quote
Old 09-14-2009, 11:05 AM   #7
Estaban
Estaban's Avatar
I don't see a whisbone in there, but cool bike none the less
Old 09-14-2009, 05:09 PM   #8
bonneville
just stay away from the model A (28-31) and the 32-34 rods, they are less than half the thickness of the 35-40's. killer idea.
bonneville is offline   Reply With Quote
Old 09-14-2009, 09:38 PM   #9
TURBO RAT
Its definately a 37, super thick wall.
Old 09-15-2009, 11:06 AM   #10
Trent
Atomic Custom
Trent's Avatar
Send a message via Yahoo to Trent
George (Spartan Frameworks) has been doing that for years. I built a Pan with one of those frames.
Atomic Trent
Atomic Custom
https://atomiccustom.bigcartel.com
http://instagram.com/atomictrent/
"Custom parts are good only when they're cooler than factory parts. By cooler I mean have better lines, work better, etc."
Trent is offline   Reply With Quote
Old 09-15-2009, 02:51 PM   #11
TURBO RAT
COOL! You got any pics? I'd like to see what one turned out like.
