S&S shovelhead oil pump - The Jockey Journal Board
Old 05-24-2009, 02:04 PM   #1
joey3380
joey3380's Avatar
Default S&S shovelhead oil pump
hello,
got a problem,
when i start my shovelhead engine (1979) with a S&S oil pump
the engine throws out 300cc oil
when it is running well then there is no leaking any more
what is my problem????
thx
joey3380 is offline   Reply With Quote
Old 05-24-2009, 07:06 PM   #2
Toecutterp
Toecutterp's Avatar
Default Re: S&S shovelhead oil pump
If you have solid lifters that might be it. Gray beard told me that. What the hell is a cc
Toecutterp is offline   Reply With Quote
Old 05-25-2009, 12:24 AM   #3
Dr. Jett
Run the bike parked on the jiffy stand with the oil tank cap off for 20 minutes, rev it, idle it, etc. Then stop the bike, shut it off, and install your dipstick/cap.
Level the bike upright.
Measure the oil level exactly then, hot, after running with the oil cap OFF.
Set your oil level to the middle mark on the oil cap.
Remember to always check the level HOT, and keep it exactly right where you set it (middle mark) forever.
Yes, it will sump when you park it for long periods, thus when you park it for a week or so, remove the oil tank dipstick/cap when you start it at home and let it run and get hot.
The vaccum caused by the tank not getting vented by the full of oil engine makes it hard for the oil pump to send it back into the tank. Vent the bitch by removing the oil cap, BUT DO NOT EVER ride it like that.
If it beomes a real pain, remove the oil pump check ball and spring and remove the check ball with a pen magnet, clean it with brakleen, and ever so slightly stretch the spring above the ball. SLIGHTLY!!!
Reinstall the ball first and then the spring and threaded cap with o-ring.
Done deal.
Yes, my beard has gray.
Or, you could be like the RUB that bought my pan that had this happen in winter after he parked it and sent it to a Las Vegas 'Ol School" bobber shop and they told him the engine was toast and he had to rebuild it. LOL!!!
Dr. Jett is offline   Reply With Quote
Old 05-31-2009, 02:58 AM   #4
joey3380
joey3380's Avatar
thx it was the ball in the oilpump, the seating was durty
Old 06-04-2009, 10:40 AM   #5
MH110
MH110's Avatar
Ok, since we're talking shovels and oil problems here is my problem.
I have an 81 FXWG. When I start the bike my oil pressure gauge shows the pressure around 40 PSI. After riding for about 15-20 minutes the oil pressure drops down to 0-5 PSI.
The oil temp goes up to 120* which tells me that the oil is circulating through the engine. Should I be running a different oil? What oil would you suggest?
MH110 is offline   Reply With Quote
Old 06-04-2009, 12:33 PM   #6
MH110
MH110's Avatar
Thanks Dragstews. But why would the pressure drop like that? Is the oil loosing viscosity?
Old 06-04-2009, 01:06 PM   #7
BigDawg
Send a message via AIM to BigDawg
60 weight.
I wouldn't worry about the gauge. I remember reading a while back that gauges are pointless under 10psi and because of the roller bearings, etc. that 5-10 psi at idle is fine. I'd be listening for shit rather than reading an oil gauge going down the road. I also read that rigid mounting an oil gauge on a shovel is about as useful as tits on a boar, seeing as you'll get more change from vibration than you will pressure.
Sometimes you just want to turn dinosaurs into noise.
The BDAC
BigDawg is offline   Reply With Quote
Old 06-04-2009, 01:09 PM   #8
Fredo
Most after market oil gauges are shit. If you really want to know if you have a presure problem run a idiot light.
Fredo is offline   Reply With Quote
Old 06-04-2009, 01:09 PM   #9
Dr. Benway
Mod Squad
Dr. Benway's Avatar
Dr. Jett, I have to try this on an S&S shovel I'm fixing for a buddy. I've done the clean ball/stretch spring trick, but even if it sits for a while (few hours) it will absolutely puke oil out the breather...I mean, a puddle.
Old 06-04-2009, 01:28 PM   #10
MH110
MH110's Avatar
Been a great help thanks.
Old 06-04-2009, 01:50 PM   #11
MH110
MH110's Avatar
Its hard to ignore the gauge when its pointing to zero. I don't hear shit banging around so I will nurse it home after letting it cool down. I'm gonna install the Adjustable pressure relief cap and go from there.
Old 06-04-2009, 11:16 PM   #12
hardxs
Not sure what kinda oil tank youre running but can you see oil returning? The S&S pumps sometime require passages to be drilled in cases depending on yr.Are you sure the lower end is the yr you think it is. S&S makes a drilling jig if needed. Overtightening pump bolts has happened in the past. May want the check pump for scoring or key way sheared.Check breather timingwhile your in there.I would say with a stock oil pump the pressure will drop off when bike is hot but the S&S is a much better pump.
hardxs is offline   Reply With Quote
Old 06-04-2009, 11:45 PM   #13
Dr. Jett
Maybe your return line hose and feed line hose are backwards at the tank?
Old 06-05-2009, 07:19 PM   #14
selectedgrub
selectedgrub's Avatar
Gauges suck, Use idiot light.
