triumph 1970 650 timing side bearing - The Jockey Journal Board
Old 02-01-2017, 11:29 AM   #1
MARIO MEDEIROS
Default triumph 1970 650 timing side bearing
Can not get the bearing out of the case,lots of heat and some tapping from the other end.Can you over heat the case using the green propane bottle torch?This one is being a pain!
MARIO MEDEIROS is offline   Reply With Quote
Old 02-01-2017, 12:39 PM   #2
tonup69
Default Re: triumph 1970 650 timing side bearing
Easiest way to do this is to bake the case half in the oven. Obviously not while your wife is home. Seriously, though, you need to heat the entire case half evenly, so maybe outside on the BBQ grill? I used an old electric oven that was in a motorcycle shop specifically for this purpose.
Good luck!
LTR
Live slow, ride fast - The Bucc
www.tonup.com
tonup69 is offline   Reply With Quote
