Motor Mount Issue - The Jockey Journal Board
Old 12-19-2010, 04:51 PM   #1
Drake9
Default Motor Mount Issue
So I got my 81 Ironhead motor back into the frame last week. I noticed something with the motor mount that has me a little concerned. I had the frame hardtailed and the bolts dont fill the new mount. I have provided a picture to show what I am talking about. I still need to get some shorter bolts for the lower bolts.....thats the one I took a picture of. So I know the bolt needs to be shorter.
So I measured some stuff with a caliper and the bolt is .375", hole is .446" and frame mount is .5" thick. So do I just bolt it up and tighten them down and ride it? I am concerned that the motor is going to move up and down to much when running so I am not comfortable with that option at the moment.
I was thinking that I could maybe have a machinist do up some spacers for me. Kinda like a sleeve with built in washer that the bolt will go through. Does that make sense?
The stock bolts are what is in there right now.
Current Ride
81 Sportster Project
My Blog
http://bublitzbikes.blogspot.com/
Drake9 is offline   Reply With Quote
Old 12-19-2010, 04:59 PM   #2
velomech
velomech's Avatar
Default Re: Motor Mount Issue
If it's tight enough, the motor wont move. if it bugs you, get the sleeves made...remember, loctite is your friends.
Cheers and Beers
Hodge
Quit yer bitchin, ride your bike, drink yer beer.
velomech is offline   Reply With Quote
Old 12-20-2010, 02:38 AM   #3
shovithead
shovithead's Avatar
Afraid not......if you don't have the spacers, you will never get it tight enough, with the full length bolts. The spacers are required to have something to torque the bolts to. I recommend the spacers, so you don't have a failure in the motormounts or front motor cases.
42 UL long term project
51 FLH short term project
60 Doc Dytch XLCH Drag only
61 XLCH parts bike
65 XLCH parts bike
66 FLH
68 XLCH parts bike
69 XLH wifies bike
69 XLH daily rider
70 XLH
72 XLH
72 C30 Chevy truck
Old 12-20-2010, 07:09 PM   #4
Lucky59
Lucky59's Avatar
^^^plus one^^^
just because it's good to be human!
Lucky59 is offline   Reply With Quote
Old 12-20-2010, 07:44 PM   #5
velomech
velomech's Avatar
wait a minute, the bolt pinches the frame between the bolt head and the motor, how can that not get tight enough? Not of my mounts are so tight the bolt fits tight in the slot, and they dont move at all....
Cheers and Beers
Hodge
Old 12-20-2010, 08:16 PM   #6
Lucky59
Lucky59's Avatar
SEMANTICS, WE ARE SAYING THE SAME THING...I was reading it as the spacer not standining proud. Just locating everything as god intended. I'm anal about shit like that, sorry!
Old 12-20-2010, 09:49 PM   #7
Richharr
Richharr's Avatar
make shouldered studs. the spacer would be .071" thick and I would think a spacer that thin would warp and oblong itself.
http://fucdatbirth.blogspot.com/
"semper fi" yeah I was miserable and tired for a few years too.
Richharr is offline   Reply With Quote
Old 12-20-2010, 10:30 PM   #8
dieselc
Could'nt you just weld the hole in the frame shut and redrill it?
dieselc is offline   Reply With Quote
Old 12-20-2010, 10:50 PM   #9
Drake9
Talked with the shop that did the work and they said that is how they do all there sportys and have had no issues. They recommended the shouldered bolts as well if I wanted to do anything but assured me it wasn't necessary.
Current Ride
My Blog
Old 12-21-2010, 01:38 AM   #10
punkrod
Use a thick fixturing flat washer, a heavy duty split lock washer and new grade 8 bolts torqued to spec and you shouldn't have a problem, (a shoulder bolt won't be strong enough). Loc-tite or safety wire will help too. However, anything you can do to take out the slop between the bolt and the slot will help to keep the bolt from loosening up. In cases like these, I'll cut a small piece of steel tubing and drill it out so it just fits around the bolt and into the slot, but not longer than the thickness of the tab. Spending a few bucks on good new hardware will save the headaches of dropped mounting bolts later.
punkrod is offline   Reply With Quote
Old 12-21-2010, 04:14 PM   #11
Young Russ
Young Russ's Avatar
I agree that a good grade 8 bolt, lock, flat, lock-tite will get the job done. Trying to make a shouldered sleeve that thin isn't necessary. Those four bolts in conjunction with each other will do the job. Not to mention, the top motor mount will be holding it down...especially if you have one between the heads.
Young Russ is offline   Reply With Quote
Old 12-21-2010, 07:27 PM   #12
velomech
velomech's Avatar
Hey pal! Who the hell are you callin a symant..simentik... a symnat...ummm, I dont know what that means.....
LOL. I get it now....
Cheers and Beers
Hodge
