Rim/Hub Offset ? - The Jockey Journal Board
Old 06-30-2007, 12:51 PM   #1
Terracite
Terracite's Avatar
Default Rim/Hub Offset ?
I laced up my rear wheel all loosey goosy and dropped them off at the shop for truing. He says I gotta get the drivetrain in, then line up the hub with tranny sproket and cut spacers based on that. Then determine the rim/hub offset to center the wheel and true it like that.
This guy seems to know his stuff, but it seems bassackwards from everything I've heard. ie -shouldnt ya lace, true, center the wheel, then shim the rest -brakes, sproket- to fit?
(Frame & wheels at shop, pics by wed)
New (1st) Build.
Kraftech rigid-set for 130 tire+dual flange wheel
Terracite is offline   Reply With Quote
Old 06-30-2007, 01:01 PM   #2
chopper76
chopper76's Avatar
Default Re: Rim/Hub Offset ?
maybe that dude is fucking with you.
Lloyd
chopper76 is offline   Reply With Quote
Old 06-30-2007, 04:25 PM   #3
bigassbike
you can do it however you want, his way probobly works for him. i usually measure the offset when i tear the wheel apart so i got it when i relace it only pull them over with the spokes if i have to... cause i cant get it any other way.
Do you even have a bike?
bigassbike is offline   Reply With Quote
Old 06-30-2007, 05:08 PM   #4
Terracite
Terracite's Avatar
Thanks guys.
Anybody got a manual for 84 st? Need offset for rear.
(It aint goin in a softy, but that's how the rear of my frame is set up.)
