Another Magneto question - The Jockey Journal Board
Closed Thread
Old 04-25-2013, 08:13 PM   #1
marvintheminnow
Default Another Magneto question
Is it true that you need a specific regulator when running a magneto with a battery eliminator on an alternator shovelhead?
I read somewhere that a standard regulator requires a 12 volt signal from a battery in order to put out juice.
this is where im reading this
http://lillianrosechoppers.com/14.html
marvintheminnow is offline
Old 04-25-2013, 08:48 PM   #2
S.T.P.
S.T.P.'s Avatar
Default Re: Another Magneto question
Yes
"Mine doesn't leak, It sweats HORSEPOWER!"- chromepig13
CLUBS R 4 SEALS
S.T.P. is offline
Old 04-25-2013, 08:50 PM   #3
BigDawg
Send a message via AIM to BigDawg
Cycle electric actually makes a no battery regulator to use with a capacitor. Remember though, you'll have no lights without the bike running. You can run a super small 12v battery (antigravity, evo2, etc.) that will allow you to use the standard charging system and keep your lights on with the mag grounded.
Sometimes you just want to turn dinosaurs into noise.
The BDAC
BigDawg is offline
Old 04-25-2013, 08:59 PM   #4
marvintheminnow
No room for a small battery. I used the battery compartment to house a remote oil filter.
Old 04-25-2013, 09:20 PM   #5
marvintheminnow
who sells the cycle electrics regulator?
Old 04-25-2013, 09:22 PM   #6
S.T.P.
S.T.P.'s Avatar
Cycle electric
CLUBS R 4 SEALS
S.T.P. is offline
Old 04-25-2013, 09:23 PM   #7
marvintheminnow
would a mechanical regulator work?
Old 04-25-2013, 09:41 PM   #8
F.St.M.
F.St.M.'s Avatar
y̶e̶s̶ no.
Edit: I apologize, I did not see the word "alternator" in your original post. I am not aware of a mechanical regulator which will work as a rectifier on an alternator setup.
Last edited by F.St.M.; 04-26-2013 at 05:35 PM. Reason: poor reading comprehension
F.St.M. is offline
Old 04-26-2013, 06:13 AM   #9
BigDawg
If you don't have a spot for a battery that small, then you don't have room for a capacitor either. The evo2 is about the size of two cigarette packs.
The BDAC
BigDawg is offline
Old 04-26-2013, 09:28 AM   #10
marvintheminnow
my capicitor is smaller that 2 cigarette packs. like I said I filled the cavity with a remote oil filter, so no there is not room for even a small battery.
Old 04-26-2013, 09:50 AM   #11
marvintheminnow
Originally Posted by Dragstews View Post
Neat little critter.....
VT No: 31-0784
Regulator mount bracket attaches to engine mount and is made of steel with a chrome finish.
Fits:
FL 1941-1984
FX 1971-1984
FXST 1984-1999
FLST 1986-1999
Could get fancy ....
Regulator Mount Bracket Stainless
VT No: 31-0951
Regulator mount bracket bolts to front motor mount.
I already have my regulator mounted in the typical kickstand bracket location in front of the alternator. unless you had something else in mind for this?
Old 04-26-2013, 05:21 PM   #12
marvintheminnow
Anyone know a specific mech regulator I can pick up at an auto parts store that mounts up similar to the stock version?
Old 04-26-2013, 07:07 PM   #13
marvintheminnow
will this work?
https://www.denniskirk.com/21292.sku...Fao-MgodznQAMg
if i order this within the next 50 minutes it will ship out today and be on my door step tomorrow
Old 04-27-2013, 08:20 AM   #14
Rasmussen
Rasmussen's Avatar
will this work?
That's for a generator. You said previously you had an alternator?
Just a thought, wouldn't it be possible to hide a small battery in the headlight? Thinking a small rechargeable drycell might work.
Rasmussen is offline
Old 04-27-2013, 10:00 AM   #15
ryangobie
ryangobie's Avatar
I'm going to need to get one of these soon for a project too but do you "need" a capacitor? Cause my generator bikes probably "need" a cap as well but the slight headlight dimming doesn't bother me.
-Ryan
ryangobie is offline
Old 04-27-2013, 01:13 PM   #16
marvintheminnow
Last night a friend of mine had working lights with the cheapest v twin regulator, battery eliminator, and magneto.
needless to say he now doubts this theory of a "special" regulator.
I on the other hand am trying to get my bike to start and run before I know my regulator doesn't work. kicking and kicking over a fresh motor last night wore me out.
Old 04-28-2013, 09:36 PM   #17
marvintheminnow
Default Hunt Magneto Spark
I am having issues with a brand new Joe Hunt horizontal magneto I just installed on my cone shovel.
my timing procedure went like this
Set motor at top dead center, both front push rods bottomed out with vertical line centered in the timing window.
Small lobe on the magneto cam is in postion to open the points.
Set points to .015
Set Autolite 4265 plug gap to .018.
I am getting spark about every 3 kicks. I am assuming this is correct as spark would only be possible when the small lobe on the cam is coming around to open the points.
The spark seams to be pretty weak. Is the appearance of weak spark associated with the tight .018 plug gap?
I am getting absolutely no firing.
I even swapped carbs to rule the carb being the issue and still no action at all.
Right now my thoughts are spark is my issue and thinking about opening the gap on the plugs in hopes to get this motor to pop off.
Old 04-28-2013, 09:42 PM   #18
JAWS
JAWS's Avatar
Default Re: Hunt Magneto Spark
Did you set the points to open right a TDC?
JAWS is offline
Old 04-28-2013, 09:49 PM   #19
marvintheminnow
The cam is coming around right at the position where the small lobe is coming in contact to open the points with the motor at TDC.
Old 04-28-2013, 09:49 PM   #20
JAWS
JAWS's Avatar
That's what I thought. Right now it would be 0 degrees.
JAWS is offline
Closed Thread
