#21 |
Well I got the new sparx rotor installed it came out of the 220 watt lit that requires a battery but I dont think that I will need a battery just using the rotor? Anyway after I installed the rotor I broke the throttle cabel. So testing has not happend yet.
#22 |
Got my throttle fixed, and fired her up now from the stater with no load I'm reading 9.3 AC volts meter set on 20 as was earlier suggested.
#23 |
So my question is, is 9.3 AC volts from the syator enough?
#24 |
ok here is what I think about this,
1. a 220 watt stator in proper working order.... will burn up just about every rectifier/regulator box that I know about if you use it without a battery. (that is why it says must be used with a battery). 2. if your ROTOR is not brand new out of a box...it's very likely no good anymore.(it does not mater what any screwdriver says.. you need a Gauss meter and nobody ever has one). 3. most stators are still good if the wires haven't been broken off or the rotor didn't melt it. 4. a magneto no-battery bike does not need a high output stator ! it needs the standard 10 amp/120 watt stator and a simple rectifier without a capacitor, ( something like a $40 Tympanium unit). 5. ....get a good used 2 wire stator, buy a new rotor if you want good lights, get a Tympainum regulator and be done with it. notes... at idle a good unregulated stator puts out about 16vac on each of the (yellow/?) wires to ground and about 24volts ac wire to wire. a 3 wire stator could be a high output 200 watt stator....or an old 6 volt 3 wire stator, ( a 6vt will work fine). a cheap volt meter often times will not give you an intelligible readout on no-battery bikes (it changes too fast)
Possibly the finest private collection of Whitworth screwdrivers in the U.S. Last edited by Tony the torch; 09-19-2016 at 08:39 PM. |
#25 |
Tony, I'm running a new 200 watt stater, a podtronix regulator/rectifier without a compaciter, and a sparx rotor that came out of a 220 kit. Sorry for the confusion.
#26 |
...is my understanding that the capacitor is to avoid the battery...
I have a tri spark 3 phase regulator with capacitor (I think is the only one in the market) because the RM24 is a three phase alternator. It s a 750 79 engine. |
#27 | |
The 200 watt Podtronics regulator will likely get hot and burn out without a battery and trying to get rid of all that unused power. at best it will need a lot of air for cooling and a good bare metal mount to get rid of all the power.
Possibly the finest private collection of Whitworth screwdrivers in the U.S. Last edited by Tony the torch; 09-19-2016 at 10:15 PM. |
#28 |
Reverb
a capacitor will take the pulses out of the lights on his bike when the it idles...that's about it. a cap is a must on a bike with an electronic ignition for it to run right.. his bike has a mag.
Possibly the finest private collection of Whitworth screwdrivers in the U.S. Last edited by Tony the torch; 09-19-2016 at 10:08 PM. |
#29 |
BPC
my advice is leave that new 200 watt stator out, and put the old one back in. use the new rotor.. is there 2 or 3 wires on the stator ?
Possibly the finest private collection of Whitworth screwdrivers in the U.S. |
#30 |
Well Tony, thats the only stator Lowbrow offers. And right now I dont think I'm worried about burning up the regulator/rectifier seeing what I'm reading from the stator. What stator would you recomend and where can I get it?
#31 | |
how any wires are on it ?............ 2 or 3 ? what happened to the old stator ?
#32 |
if you really are just getting some low voltage reading, either something is wrong with the charging system or the metering ..so... fire it up and see what happens.
the charging system will not make any difference in the way it runs ....if you have a separate magneto system for the ignition.
#33 |
with a 3 phase 200 watt 3 three wire stator actually puts out less power at low rpm than a 120 watt 2 phase 2 wire stator !
the reason is it takes more revolutions for 3 phases to pass over and over (or frequency) ...than it does for 2 phases to pass over and over. so at low rpm you have lower frequency and actually get less voltage...
Possibly the finest private collection of Whitworth screwdrivers in the U.S. Last edited by Tony the torch; 09-20-2016 at 12:13 AM. |
#34 |
I can tell you what works on my (magneto and batteryless) Enfield.
I have a 120 Watt Lucas stator with a Sparx rotor and a Pazon Battery Eliminator. I run a 65 Watt H4 headlight and an incandescent stop/tail light. When converting from points and coil ignition to magneto, I realised that I’d have some spare Watts to get rid of with this set up, so I wired the bike so the headlight was permanently on. Works a treat. |
#35 |
Tony, its a 2 wire stator, the old one the wires were bfoke at the base.
#36 |
ok then put it all together, make sure you have about 2k clearance all around the stator and rotor.
fire it up and see what it's putting out.
