I have seen custom bikes with electric start but really couldn't see the battery. I'm building my first bobber it's a 75 shovel any suggestions on hiding the battery?
i've used lithium ion... made battery packs with both a123 LiFePO cells, and tearing into a dewalt battery pack for its mystery cells. worked well, able to turn over the motor in my suburban without issue. if i were to do it again, i'd just buy a pack.
eventually i fried the last pack i made... now i'm using a lead acid. old school reliability.
"OK, working on MY STUFF for a change. Under-transmission battery tray and electrical box for my CFL. Love these Antigravity batteries. 3.4 lbs, 480cca. One hand holds the tray up effortlessly, the other hand installs the bolts......"
I see somebody actually looks at my Facebook page, haha! I've had good luck with the Antigravity batteries, and yeah, you can stash them just about anywhere. Eric, that owns Antigravity Batteries, is a very knowledgeable guy, and his customer service is 2nd to none. In the case of the 16 cell battery I'm stashing under my 5 speed transmission, I originally designed the tray to take a Softail-sized battery, with 320cca, and a weight of 14 lbs. The 16 cell Antigravity weighs 3.4 lbs, and has 460cca., and is about 1/2 the size of the Softail battery.
But, if you want to stick with an AGM battery, a Softail-sized battery will fit in the area under a 4 speed, and it'll hang below the frame rails about 3/4", which as far as ground clearance loss goes, even with 11" shocks (as on the bike here), is minimal. I've done several of those trays to stash the battery under the trans, and you can see one of them peeking out below Randy's frame here.....
I apologize for the preemptive strike.. You do some really cool work down there in the land of legal pot...
Related Threads
Jockey Journal Forum
994.9K posts
82.4K members
Since 2005
