akront rims / spoke nipple size - The Jockey Journal Board
Old 01-17-2015, 06:18 PM   #1
Loffer
Loffer's Avatar
Default akront rims / spoke nipple size
I have a 40 hole akront that I was told was used on a triumph cotten spool hub. So I " assumed I'd be dealing with the same spoke pattern and nipple size for an 18" rim so I got a standard set of triumph 18" spokes and right off the nipples are a lot larger than the holes. Considerably . I am thinking I have a rim that doesn't match or the holes would fit standard spokes . anybody familiar with these setups that would know? What I know is if I had a dunlop rim I'd be lacing a wheel right now so I have the stock size spokes . thanks k.
Old 01-17-2015, 09:07 PM   #2
caschnd1
caschnd1's Avatar
Default Re: akront rims / spoke nipple size
Maybe the rim was used on a wheel with a different gauge spoke set. You could always just drill the holes to match your spoke set. Be careful to pay attention to the angle of the holes.
-Craig
caschnd1 is offline   Reply With Quote
Old 01-18-2015, 07:44 AM   #3
Loffer
Loffer's Avatar
Default
Thanks Craig . I was considering drilling them out. Also wondering of you can use a different nipple size? The spokes are 8ga I believe the nipples are huge .
Old 01-18-2015, 09:09 AM   #4
Ducbsa
Take a look at the Buchanan's site, they probably have different nipple OD's for the same spoke size.
Old 01-18-2015, 01:44 PM   #5
caschnd1
caschnd1's Avatar
I just measured the nipples that came with my Buchanan Stainless Spokes set (used in an Akront 18" rim and the O.D. of the nipple is 0.281"
I just checked Buchanan's web site. For 8ga spokes, they make 0.281", 0.300", 0.320" and 0.343" O.D. nipples (stainless).
-Craig
Old 01-18-2015, 02:12 PM   #6
Loffer
Loffer's Avatar
Default
Thanks for the reference Craig I think I will go that route instead of drilling I'll check my hole diameter . thanks for the replies I appreciate it . Ken.
