1959 pre unit build . - The Jockey Journal Board
Old 12-14-2014, 09:50 AM   #1
Loffer
Loffer's Avatar
Default 1959 pre unit build .
I have been working on this for a few years from time to time . mostly working with parts I had and a few basic fabs and mods to make @ duplex look like a rigid pre unit . getting ready to finish and reassemble so I collected some photos of the work so far. Here's what I started with..
Old 12-14-2014, 09:57 AM   #2
Loffer
Loffer's Avatar
Default
I'm a bit of a hack monster . I can weld OK. Not pretty so I molded all the welds . I slugged the tubes where it was cut . I'm pulling images from google so they might not be the best pics.
ID:	168529   Click image for larger version
ID:	168537   Click image for larger version
ID:	168553   Click image for larger version
ID:	168561   Click image for larger version
Old 12-14-2014, 10:18 AM   #3
Loffer
Loffer's Avatar
Default
Its a t-100 front end - nancell tubes are shortened and added 1" risers . ducati front 21" and rear 18" akront . I made a tank I liked but tried to braze it and couldn't stop leaks. Next time I know what to do ..
ID:	168585   Click image for larger version
ID:	168593   Click image for larger version
ID:	168609   Click image for larger version
ID:	168617   Click image for larger version
ID:	168633   Click image for larger version
ID:	168641   Click image for larger version
ID:	168657   Click image for larger version
ID:	168665   Click image for larger version
Old 12-14-2014, 10:36 AM   #4
Rob Axel
Rob Axel's Avatar
Default Re: 1959 pre unit build .
Looks great so far...,keep posting. Do you plan on tearing I to the motor at anytime?, any "upgrades" planed??
"The heart is happiest
Old 12-14-2014, 10:51 AM   #5
Loffer
Loffer's Avatar
Default
Thanks Rob . yes I'm about to tear into the motor. Its 20 over now so a clean up or rebore and new pistons to come. See what's lurking in the bottom end. Its gonna have a unit primary and clutch it had tthaf setup already and I have newer parts for it. I heard they don't fit under the primary cover with a stator but it fits under this one OK. Trans is already rebuilt .
Old 12-14-2014, 11:41 AM   #6
Desert
Desert's Avatar
I like it and will be watching, hopefully I can pick up some tips. Im collecting parts for a 57 in a custom duplex frame. Everytime I have a look or attempt to work on the triumph its so fugly I cant seem to get much done. Maybe if I throw a blanket over the beautiful BSA sitting next to it I wont be so bias
Desert is offline   Reply With Quote
Old 12-14-2014, 11:50 AM   #7
vorhese
vorhese's Avatar
I'm bummed, JJ isn't loading the pictures for me.
Old 12-14-2014, 11:58 AM   #8
HD48FL
Super Moderator
Likewise, but I don't think it's the JJ?
Old 12-14-2014, 12:11 PM   #9
Rob Axel
Rob Axel's Avatar
No issues here....
Old 12-14-2014, 12:27 PM   #10
Loffer
Loffer's Avatar
Default
I can't see some . I'll go back later and try to reload .
Old 12-14-2014, 01:40 PM   #11
Desert
Desert's Avatar
Old 12-14-2014, 01:50 PM   #12
[email protected]
thomassuman@mac.com's Avatar
loffer - are the stairs the only way out when your done ?
thomassuman@mac.com is online now   Reply With Quote
Old 12-14-2014, 02:11 PM   #13
dvrogers
dvrogers's Avatar
Default
It's about time Ken!
dvrogers is offline   Reply With Quote
Old 12-14-2014, 03:11 PM   #14
Loffer
Loffer's Avatar
Default
No. the stairs ? They go up . Bikes on the ground floor
Old 12-14-2014, 03:49 PM   #15
Loffer
Loffer's Avatar
Default
Originally Posted by Desert View Post
I like the looks of this
Old 12-14-2014, 05:23 PM   #16
VonWegener
VonWegener's Avatar
Loffer, I really dig the elegant simplicity of the fender strut / grabrail. So many bikes nowadays have these ugly curved struts or overly elaborate setups. Very well done.
Old 12-14-2014, 05:49 PM   #17
Loffer
Loffer's Avatar
Default
Thanks Von, I am going for simple look i have seen in old pics and some recent builds . lots a handwork , grinding and filing . I have a ton of hours in this thing . more than it looks like but most of that is the frame .
ID:	168833   Click image for larger version
ID:	168841   Click image for larger version
ID:	168857   Click image for larger version
ID:	168865   Click image for larger version
Old 12-14-2014, 05:49 PM   #18
Loffer
Loffer's Avatar
Default
I know !
Old 12-14-2014, 06:22 PM   #19
vorhese
vorhese's Avatar
any chance you could post some pics to imgur and post them. I've tried to see the pics, but this post isn't working for me.
Old 12-14-2014, 06:30 PM   #20
HD48FL
Super Moderator
Same here!
