S&S MG "L" Carburetor - The Jockey Journal Board
Go Back   The Jockey Journal Board > The Jockey Journal Marketplace > The Swap Meet > Parts For Sale
Old 07-06-2012, 09:35 AM   #1
weishaarkc
Default S&S MG "L" Carburetor
City: Richmond
State: VA
Price: $500
A nice clean S&S MGL Carb with the accelerator pump mod. Bowl is clean and corrosion free but is drilled so you can insert a fitting (or plug it if you dont want to use the pump) to provide fuel to the accelerator pump that is attached with brackets to the bottom of the carb. Comes with the manifold and everything you see in the photos. $475 shipped (with insurance) to your door in the lower 48. More if you live somewhere else so message me first.
weishaarkc is offline   Reply With Quote
Old 07-06-2012, 12:02 PM   #2
Monte03
Monte03's Avatar
Default Re: S&S MG "L" Carburetor
Accell Pump on and 'L' Carb??? I need to know more, was this added from another carb?
I realize your L is the Last of the Series that ended late 70's early 80's,
Thanks,
Monte
Monte03 is offline   Reply With Quote
Old 07-06-2012, 12:28 PM   #3
weishaarkc
Yes this is the late model (L) of the early S&S carbs. I'm pretty sure the pump is a Mikuni and this was a fairly popular modification to these carbs. Some used Thunderjets instead of an accelerator pump but this makes it the same as a modern carb. You can check this thread for more info. It's not exactly the same but the same general principle.
Old 07-09-2012, 08:31 AM   #4
weishaarkc
Ttt
accelerator, carb, carburetor, mgl, s&s
HTML code is Off
