Retro Custom 67 T120 Project - Page 7 - The Jockey Journal Board
Old 08-20-2012, 03:09 PM   #121
Cosmoline
Cosmoline's Avatar
Default Re: Retro Custom 67 T120 Project
Oil Tank progress...
My current build, a garage-built pre-war inspired 1967 T120R.
Cosmoline is offline   Reply With Quote
Old 08-21-2012, 10:36 AM   #122
S.G
S.G's Avatar
Looks like good progress, keep the good work and picures up...
My 1962 Panhead https://www.jockeyjournal.com/forum/...ad.php?t=99316
S.G is offline   Reply With Quote
Old 08-23-2012, 06:30 PM   #123
Cosmoline
Cosmoline's Avatar
Thanks S.G. - made some more progress on the oil tank today. Internal windage box and lines all set, just need to weld everything up.
Also figured out how I want to mount the tank up. Basically there will be 4 tabs on the frame downtube under the seat which I'm making to this spec:
And then there will be 4 threaded bungs welded to the side of the tank which line up with the tab holes - in between the two I have some bonded rubber bushings with 1/4" thread on each end to mate the bungs on the oil tank to the brackets...
Oh and my internal spring kickstand also came in. Nice clean look.
Old 08-29-2012, 10:28 PM   #124
Cosmoline
Cosmoline's Avatar
I did finish up the welding/brazing on the oil tank and pressure tested it successfully. I still need to weld on the bungs, hit it with some sanding sealer, and take some pics. Not much progress the last week or so due to a combination of incredibly nice weather and a new addition to the family...
Old 10-18-2012, 04:55 PM   #125
vintagespeed
awww man, you're never gonna finish now!!
i dig the side stand, might need to find me one of them.
-jb
that's JunkBitch to you.
vintagespeed is offline   Reply With Quote
Old 10-28-2012, 07:43 PM   #126
Cosmoline
Cosmoline's Avatar
I will finish! I'm just trying to get in every bit of riding before the snow hits. Once that happens, I'll be working on the bonnie in the basement all winter.
Here's the current state of the luxe which has seen quite a few mods since I got her...
Old 10-28-2012, 07:53 PM   #127
nigel
Oh and my internal spring kickstand also came in. Nice clean look.[/QUOTE]
Is that a Hot Match stand? Looks like one
nigel is offline   Reply With Quote
Old 10-29-2012, 06:43 AM   #128
Cosmoline
Cosmoline's Avatar
Is that a Hot Match stand? Looks like one[/QUOTE]
They're from Led Sled Customs:
http://www.ledsledcustoms.com/produc..._section=Parts
Old 11-21-2012, 12:01 PM   #129
vintagespeed
HEY, is it snowing yet! where's the update??
-jb
Old 11-22-2012, 07:09 PM   #130
Cosmoline
Cosmoline's Avatar
I'm almost done moving everything down into my basement for the winter. Had to demo some existing stuff, build some new workbenches, put in some pegboard and lights, get the lift table and bike down there, bring all the tools down, etc. Should have a new update next week!
New shop name is Boiler Room Basement Customs.
Tags
1967, bonneville, classic, custom, t120r
