Triumph 68 forks front end lowering - The Jockey Journal Board
Old 03-23-2014, 10:00 AM   #1
djchaz
Default Triumph 68 forks front end lowering
I have a 2.5" lowered 4" stretch hard tail in order to have it sit level I should lower the forks I have extra plastic spacers to use but I wanted to use progressive springs I will need to shorten these correct or will I get a better ride if I use the 2" pre shortened springs from tmwf As I understand the progressive spring is a much improved ride though what happens if I need to shorten them? Any prior experience with this would be appreciated.
djchaz is offline   Reply With Quote
Tags
bonneville, forks, springs, triple tree, triumph
