Bonneville & LSR Update - Page 6 - The Jockey Journal Board
Old 03-07-2014, 03:28 PM   #101
dandruff
dandruff's Avatar
Default Re: Bonneville & LSR Update
Dude! That frame is amazing
dandruff is offline   Reply With Quote
Old 03-07-2014, 06:59 PM   #102
Hoofhearted
Hoofhearted's Avatar
A record setter sitting still! El Mirage in May Alp?
Old 03-08-2014, 12:23 PM   #103
astek
astek's Avatar
I will install the 650 M-VG engine in to this new frame to test it in May at El Mirage. But the ultimate goal is to finish the 650 Pushrod Fuel engine for Bonneville Speedweek!
www.alpracingdesign.com
Old 03-08-2014, 04:18 PM   #104
Truckedup
Astek, you do nice work that's for sure and I don't believe there's a faster running Triumph 650 than yours on any LSR track. We're the fastest east of the Rockies ......... It's interesting to see the difference between vintage MP and my Triumph 650 in non vintage MP. You can get you seat height lower than the top of the rear tire...
El Mirage doesn't have MP class, just altered class????
Old 03-08-2014, 05:28 PM   #105
Hoofhearted
T U, No Modified class at El Mirage. Just A.
Old 03-08-2014, 09:40 PM   #106
astek
astek's Avatar
Thanks Truckedup, Yes El Mirage does not have M class so i can run my new "A" frame (special construction) without changing classes.
But SCTA/AMA M-VG and M-PG is the same, your seat height can not be lower than the rear tire.
Here is my M-VG 131 top speed at Bonneville with the stock frame and the seat above tire.
Old 03-09-2014, 06:38 AM   #107
Ducbsa
What is the function of the drilled plate behind your left foot?
Originally Posted by astek View Post
Old 03-09-2014, 06:45 AM   #108
Truckedup
Do you use the long megaphones because of results from track or dyno testing? It appears that some LSR racers use long individual pipes, some use shorter and some a two into one. Otherwords, no golden rule for pipes.
I fabricated a two into one with 27 inch primaries and a 16 inch collector. This is similar to used on the best running AHRMA Triumphs...See how it goes on the dyno..but...
We been having ignition issues and missed dyno tuning....I bought a new $450 Pazon Smart Fire and the fucker was bad out of the box. I've used other Pazon ignitions with no problems. Emailed Pazon and that day they closed for a month....Vacation of some sort. They don't open until March 16 So I'm just hanging here waiting.... Oh well.
Old 03-09-2014, 03:58 PM   #109
astek
astek's Avatar
I made the alloy plate so i can change the location of the foot controls according to class.
M class requires that the foot rests must be ahead of the rear axle at least by 6
Truckedup,
Magneto my friend "MORRIS MAGNETO". You put it on and you do not worry about it anymore. Simple, efficient very strong and made by a great guy here in the USA.
I am not done with all the options in terms of exhaust design. So far this works fine but there could be better alternatives. I have no idea what my engine would do on the dyno with its current set-up. I'm looking forward to seeing how your 2 to 1 will perform.
Old 03-10-2014, 01:03 AM   #110
gasketscraper
Damn, Alp you just constantly improve from awesome to amazing to unreal! That is some beautiful Fabrication. Looks like a record setter to me. The carbs look great. Lots of love and time put into them. Best of luck to you.
Lets Hang Glide off the Fiscal Cliff!!
gasketscraper is offline   Reply With Quote
Old 03-10-2014, 01:24 AM   #111
Dean Lowe
Dean Lowe's Avatar
The long slim megaphones generally work better at higher RPM's. Depends on the cam, but our Honda gained almost 1000 RPM's at Bonneville with this CR 110 style megaphone over a short Bates megaphone.
Dean Lowe is offline   Reply With Quote
Old 03-10-2014, 04:40 AM   #112
astek
astek's Avatar
Yeah lots of time, that's for sure! Thanks for the kind words.
Wow, another 1000RPM just with a different megaphone! My engine would blow up with another 1000rpm. But I think you are right about the longer megaphone working better at high rpm.
Old 03-10-2014, 05:58 AM   #113
Truckedup
Long exhaust is not a given for top end performance. Tim Joyce's bike was a consistent winner in the AHRMA 750 class. It's a heavily modified Triumph engine making around 80 hp at 8000 rpm. Yes it's a road racer but top end power is still important.
Or this machine, it's the current 1000 cc pushrod record holder at 157 MPH. This Moto Guzzi is like many Harley's with a shorter exhaust...Different crank phasing, but not all that different. Modified Guzzi's turn over 8000 rpm.
A Triumph with a 360 degree crank is more like two single engines that the 450-270 degree Moto Guzzi....But I'm going to try out the shorter two into one just to see what happens..
Exhaust is just one three major tuning variables, the other two being intake length and camshaft.
But it's hard to argue with Astek's exhaust considering 130 MPG speed run...
Old 03-11-2014, 03:24 AM   #114
astek
astek's Avatar
Very nice race bikes! Thanks for posting the pictures.
The 750cc with 80hp at 8000rpm is impressive, seems like the 2->1 works well. You probably will end up with 55-60hp or more on your 650cc with that type of exhaust, and that will do the job! Let us know.
Old 03-11-2014, 06:00 AM   #115
Truckedup
Last year when first built our bike made 51 rear wheel HP at 7000 rpm on a Mustang dyno. Mustang dynos are supposed to be more realistic than the Dynojet...The dyno operator was having trouble with the machine so I think the HP may be less than he claimed.
You have dyno numbers?
Old 03-11-2014, 05:10 PM   #116
Blown CBR
Blown CBR's Avatar
Iv'e just returned from the DLRA Speedweek event (Australia), I didn't get the "toy" bike sorted, but had a GREAT time crewing for a mate, Filthy, on his 'ol Shovel (Phil has only one leg)
This leg freaked the scrutineers out
Spent most of the week chasing Nos gremlins, ended up wiring the one shot system to the hi/low lite switch as the 3 stage system refused to work.
He was having a good run, just crossed the 1st timer on the 3 mile marker, when a coil wire broke, he still managed 135 mph, on ONE cylinder !
His best run was looking like upping his 152 mph record, pulling 6,500 rpm in top, Nos had been "stabbed" several times, just to be told the timers went down,,no time recorded.
http://youtu.be/dkSsW2gtdj0
Oh yeah, shredded a 3" belt too on an earlier run.
Tiny
Blown CBR is offline   Reply With Quote
Old 03-11-2014, 07:52 PM   #117
astek
astek's Avatar
I haven't dynoed this engine, but they say it is probably close to 60hp to go above 130mph.
Tiny
Lake Gairdner looks beautiful in the video. Congrats to your mate too.. Any 650 vintage/pushrod bikes?
Old 03-11-2014, 08:21 PM   #118
Blown CBR
Blown CBR's Avatar
"Any 650 vintage/pushrod bikes? "
Yes, prelim results here
http://www.dlra.org.au/2014.htm
This clip is of the drive to the pits, the salt was different than Iv'e ever seen it, no hexagonal pressure ridges, just the occasional "moon rock", apparently . draw up by the the moon's gravitational pull ?
There was a 2" coating of salt with a sandy texture, under this were salt crystals that were transparent, and looked like coarse rock salt, the Harley dug down to this and got traction,
http://youtu.be/9xgN5JAXGMo
Tiny
Old 03-12-2014, 02:12 AM   #119
Dean Lowe
Dean Lowe's Avatar
Wow, another 1000RPM just with a different megaphone! My engine would blow up with another 1000rpm. But I think you are right about the longer megaphone working better at high rpm.[/QUOTE]
The little 100cc Honda with it's overhead cam, lightened rockers, and stout valve springs doesn't complain near 10,000 rpms. Setting two records it ran a total of 30 miles full throttle.
Old 03-12-2014, 03:47 AM   #120
astek
astek's Avatar
I know your bike, it's not just a race bike, it is a work of art.
Tags
alp, bonneville, pre unit, salt flats, triumph
