113.275 MPH Pre-Unit Salt Flat Racer build by alp - Page 2 - The Jockey Journal Board
Old 08-22-2011, 11:29 AM   #21
model-a-fan
model-a-fan's Avatar
Default Re: 113.275 MPH Pre-Unit Salt Flat Racer build by alp
Good for you boss! Looks like a blast....
model-a-fan is offline   Reply With Quote
Old 08-22-2011, 03:03 PM   #22
astek
astek's Avatar
Thank you guys,
Originally Posted by Hoofhearted View Post
Well.......I think you know the answer to that question. Sept. 11 will give you the answer. I'll be there but not racing. Bonneville bust me financially but coming home with two records takes the sting out of it.
P.S. I would love to see you there and see how the Triumph runs in the dirt. I suspect the answer would be, pretty good.
Hi Bill, same here. i really want to run at El Mirage, we'll see if i can get that going, You'r ok as a spectator with all those records under your belt, let us do the running
Here are other images on our way to Bonneville,
Stoped in the Mojave desert somewhere in Nevada to take some pictures..
www.alpracingdesign.com
astek is offline   Reply With Quote
Old 08-22-2011, 03:46 PM   #23
Hoofhearted
Hoofhearted's Avatar
Love the photos. Especially the last one. Only in Nevada could you walk out into the middle of highway 93 and take photos in complete safety! Between Vegas and Ely really is "somewhere". That whole stretch of highway tends to blend into one long "somewhere".
El Mirage record 500 APS/PG 129.817 mph
El Mirage record 500 SC/PG 122.240 mph
El Mirage record 500 SC/PF 120.157 mph
Bonneville record 500 SC/PG 119.667 mph
Bonneville record 500 SC/PF 117.186 mph
Bonneville record 500 SC/PBG 111.494 mph
Bonneville record 500 SC/PBF 112.717 mph
Bonneville record 650 SC/PF 128.703 mph
Bonneville record 650 SC/PG 121.553 mph
El Mirage record 650 SC/PG 130.224 mph
Hoofhearted is offline   Reply With Quote
Old 08-23-2011, 09:32 PM   #24
lowbrowcustoms
lowbrowcustoms's Avatar
Alp, way to go! I didn't see you after that faster run, that is very good.
The DA on Friday morning was super low. Something like 3,800 ft (!!!). I picked a bad morning to jet down and run at my leanest of the week. An hour later ran again and while it was a bit over 80 degrees was still under 4,000 ft DA! Crazy.
lowbrowcustoms is offline   Reply With Quote
Old 08-24-2011, 03:49 AM   #25
Shacknasty
Congratulations and thanks for posting all the great photos. A skinny, stripped-down motorsickle just looks soooo right with a thick crust of salt.
Shacknasty is offline   Reply With Quote
alp, bonneville, pre unit, speed, triumph
