Ironhead Oil Pump - The Jockey Journal Board
Old 09-02-2015, 01:52 AM   #1
Ravnur
Ravnur's Avatar
Default Ironhead Oil Pump
Hi
Got an 71 motor, wanna fit a 72 oil pump, will it work..?
If so, dosesnt look like the holes are the same, while fitting the body on the case.. :-) ??
Thanx..
Ravnur is offline   Reply With Quote
Old 09-03-2015, 11:45 PM   #2
btcoop
Default Re: Ironhead Oil Pump
Hello Ravnur -
This is the only forum on which I am a member, however, as no one here has yet responded to your very good question, I will venture to say that another forum on which Dr. Dick resides will certainly be able to answer it fairly quickly. Sportsters seem to have a somewhat narrow niche following. Google "XLForum".
All the best,
btcoop
Houston
btcoop is offline   Reply With Quote
Old 09-04-2015, 07:17 AM   #3
Ravnur
Ravnur's Avatar
Hello btcoop
Thanx for info, I will try that way around.. :-)
Best...
Old 09-04-2015, 08:03 AM   #4
image1's Avatar
are you sure its a 72 pump? ...i was thinking that pumps were the same until the mid 80s?
August 4-7, 2016!!!!!!!!!
http://r4yl.blogspot.com/
Old 09-04-2015, 08:23 AM   #5
ProSimex
It's the same thing
ProSimex is offline   Reply With Quote
Old 09-04-2015, 09:40 AM   #6
Dave B
Bolts right on and should have a slightly larger window for better oiling.
Dave B is offline   Reply With Quote
Old 09-04-2015, 09:59 AM   #7
joe49
joe49's Avatar
57 and up till the mini sumps came will fit.
Old 09-04-2015, 01:00 PM   #8
chevelle
Use earlier OEM solid drive pin.
You can drill the case return to match the double hole -72 cast iron pump housing but it's not absolutely necessary.
chevelle is offline   Reply With Quote
Old 09-08-2015, 03:33 AM   #9
Hopper
Hopper's Avatar
The major oil pump change came in late 1976, to the modern gerotor type. Before that was the gear pump which should be the same, more or less, from year to year.
Hopper is offline   Reply With Quote
Old 09-12-2015, 08:40 AM   #10
Maniacles
Get a decent gasket/ seal kit making sure you replace the shaft seal. Thrice check that the holes line up on all the gaskets. They are pretty similar between the early and 72ish type and easy to screw up. Ask me how I know.
Mind that the keys line up and the locking collar seats. If it's more than a slip fit into the motor, or there' a gap on the bottom plate, somethings wrong. Put down the brick.
Before you buy a used pump, check that the gears aren't buggered from dead meatal going through the pump and that some trog hasn't overtightened the threaded hole where the oil pressure switch goes and stripped / cracked it.
Hey there daddy-O! Make mine type O! (positive)
www.manxmc.com
Maniacles is offline   Reply With Quote
Old 10-23-2015, 01:52 AM   #11
Ravnur
Ravnur's Avatar
Thanks for the help.. :-)
Tags
ironhead, oil pump
