Got an 88" stroker S&S motor running Andrews C grind cam and cannot get the carb to get past firing,wont carry on running. Been fitted with a rebuild kit,pumper puts fuel in ,fires on that initial fuel then dies .Any help would be greatly apreciated as no-one in australia seems to be able to help me ,cheers all
I read that and i just had exactly the opposite on a CV carb
hard to start bike but eventually did and no fuel from pump accelerator nozzle. Reason was gummed up ball bearing under brass nozzle.(after checking diaphragm first)
Pulled out cleaned and she's a squirter.
This may sound rudimentary, but you do have good fuel flow from the tank?
Plugged filter....collapsed or rotted fuel line?
Lots of fuel in the tank(creating a pressure, somewhat)?
Does the piston slide up and down easily and is the correct oil inside so it dampens the movement and seals it? Do you pull enough vacuum to even make it slide. Have you tried to tickle it by squirting raw gas in side the manifold before a starting attempt?
@John the Hat- I've run SUs on shovels and pans, and liked them. However I had one shovel that I tried to run one on, and I simply could not get the 2 play nicely together. It would start, but then anything below like 1200-1500 RPM and the slide was bouncing up and down too much to idle. I tried lube, springs, etc. I finally just put on a butterfly carb and chalked it up to a combination of cam, timing, carb.
Related Threads
Jockey Journal Forum
994.9K posts
82.4K members
Since 2005
