Round coils - The Jockey Journal Board
Old 01-08-2020, 04:10 PM   #1
Malamute
Malamute's Avatar
Default Round coils
Whats the consensus on the older style round chrome coils, are they OK, and particularly with electronic ignitions? I believe I have a Dynatek on the 84 shovel.
I used a round chrome coil on my knuckle, but it was standard points and condenser ignition. Never had any problems with the coil, but I have no idea what the current ones are like and if compatible with electronic ignitions.
Malamute is offline   Reply With Quote
Old 01-09-2020, 01:42 AM   #2
tgb3040
Default Re: Round coils
An ignitions system with points needs a coil with higher resistance compared to an electronic system that most often uses a lower resistance coil.
Best
tgb3040 is offline   Reply With Quote
Old 01-09-2020, 09:47 AM   #3
...unless it's a Dyna S, which uses a points-style coil.
Old 01-12-2020, 02:56 PM   #4
Malamute
Malamute's Avatar
Its an 84 FXS with I believe a dynatek ignition.
The coil info showed 4 ohms. The majority of other coils Ive seen seem to fall in the 3 or 5 ohm brackets.
Are the round coils generally reliable, assuming proper application?
