slipping kicker ratchet top - The Jockey Journal Board
Old 04-26-2016, 11:45 PM   #1
jeffy
Default slipping kicker ratchet top
whats up guys, here i go again with a most likely noob question again. i have got an intermittent stripped/slipping spot in the kick on my bike. every now and then when im trying to kick it through it starts with a grab of the teeth and part way down BAM! its gone and stomp the ground....you know the drill. i pulled the cover off thinking it was going to be something about the gears in there, but they all look just fine to me, so i can only venture i guess that i might be going inside the main case and working on that then???
jeffy is offline   Reply With Quote
Old 04-27-2016, 01:29 AM   #2
'59
Default Re: slipping kicker ratchet top
do a search, I had a similar problem buut slipping constantly towards bottom of swing about the 7-8 o'clock position, seems it was the worn main shaft starter gear teeth. the wear wasn't really that appreciable until compared with a new one.
now, fitting an aftermarket one and getting it to mesh correctly with the kicker starter gear is another balls ache, luckily sorted with some guidance from JJ feedback.
'59 is offline   Reply With Quote
