trio of trumps - The Jockey Journal Board
Old 06-05-2009, 12:46 PM   #1
image1's Avatar
Default trio of trumps
fucker's seem to be multiply-ing in my shop. Waiting on my crank(S) to get back from the machine shop, and another box of parts, but this is what i have ahead of me....
looks fun huh?
RUN FOR YOUR LIFE Mother F*cker!!!!
August 4-7, 2016!!!!!!!!!
Random Chopper Goodness at the link below....
http://r4yl.blogspot.com/
image1 is offline   Reply With Quote
Old 06-05-2009, 12:51 PM   #2
not45blesk
not45blesk's Avatar
Default Re: trio of trumps
Goody Good ... !!!
All seem nine stud though.
Talk about an artistic display...
Probably it should show on friday art too.
keep it up
Knot Blesk
3ciprestescycles
http://3ciprestescycles.blogspot.com
http://fatfredtowing.blogspot.com/
not45blesk is offline   Reply With Quote
Old 06-05-2009, 01:04 PM   #3
caveman
looks to me that you had driven the middle one with to high rpm,s ( broken rod)
where ever you go, go hard
caveman is offline   Reply With Quote
Old 06-05-2009, 01:09 PM   #4
image1's Avatar
( broken rod)
actually, all of these are broken rod motors...
1. open primary clutch bearing went
2. po reversed oil lines and spun rod
3. sludge trap, spun rod
4. not sure, but crank was WASTED, several thousandths below min spec for a -.020
Old 06-08-2009, 08:47 AM   #5
image1's Avatar
After watching TroyFab's build, and his 'shark fin' removal i decided i REALLY liked that look, and so i did it on my engine as well, but i also went a little further and cut off the top section of the cover AND the outer transmission housing. I rounded it all out and blended the housing to where it looks factory. I'm stoked about how it all came out, looks kinda like pre-unit in a way.
Stock Example:
After Modifications:
Old 06-08-2009, 04:48 PM   #6
lowlife_slim
lowlife_slim's Avatar
i aint clicking that shit...
looks like you have a lot of man-hours ahead of you. good luck.
"what year Sportster is that?"
lowlife_slim is offline   Reply With Quote
Old 06-08-2009, 08:21 PM   #7
Bozi
Bozi's Avatar
Got an extra head? :-)
Post up some pics as you go with one of them.\
You got bikes, or are you in starting stages of a build or 2 or 3?
Bozi is offline   Reply With Quote
Old 06-08-2009, 11:27 PM   #8
76flh
Man! that looks cool with all those trump parts laying on the floor like that.
good luck,
76flh
76flh is offline   Reply With Quote
Old 06-08-2009, 11:50 PM   #9
Drakkule
Drakkule's Avatar
I'm willing to adopt one of them, i promise to give it a good home.
Drakkule is offline   Reply With Quote
Old 06-09-2009, 08:51 AM   #10
image1's Avatar
no, i'm lookin for a single carb head too...
You got bikes,
This is one (its under going some changes)
This is the other
Old 07-07-2009, 12:40 PM   #11
VOH
VOH's Avatar
This is the other
where are the pipes from?
VOH is offline   Reply With Quote
Old 02-22-2010, 07:21 PM   #12
villa
villa's Avatar
i love it.............
villa is offline   Reply With Quote
Old 06-09-2009, 08:53 AM   #13
image1's Avatar
got some more work done last night on the 'hot rod' motor. Finally tracked down a lay shaft 3rd gear (hard to find 5 spd parts) and got the transmission all put back together, new bearings throughout. Also did some more fat trimming. I am retro-fitting (this is a 71 tr6) earlier style cam wheels to some Megacycle cams to go in this engine, and decided that they needed to lose some weight.
Stock timing gear set, thick and bulky
Earlier (68) timing gears, on a diet.
Old 06-17-2009, 10:27 AM   #14
image1's Avatar
tag/tail light mount done, coil mount done, battery box done. Pics.
*fender fits nicely, but wheel has no bearings and is not sitting straight at all.
Old 06-17-2009, 11:26 AM   #15
6T Sinner
6T Sinner's Avatar
Those timing gears look nice! How'd you do it?
6T Sinner is offline   Reply With Quote
Old 06-17-2009, 12:05 PM   #16
image1's Avatar
thanks. layed out a pattern, made a jig to hold them true in the drill press, and then just rotated the gear in the fixture to keep spacing the same.
Old 07-07-2009, 09:55 AM   #17
image1's Avatar
some gooder pics from last night. Its bare bones, no frills for sure. Dude is bout outta money so its not getting any fancy stuff. Engine for this one is getting close to being done.
Old 07-07-2009, 12:34 PM   #18
Ken Cormier
Man I like that style
Ken Cormier is offline   Reply With Quote
Old 07-07-2009, 01:01 PM   #19
image1's Avatar
egay, don't remember the seller though
Old 07-07-2009, 01:14 PM   #20
jeep44
I like that look when the "shark Fin" is removed.
jeep44 is offline   Reply With Quote
