The designated springer ID thread - Page 6 - The Jockey Journal Board
Old 08-24-2011, 09:43 PM   #101
jakespade77
jakespade77's Avatar
Default Re: The designated springer ID thread
Originally Posted by hdshovel82 View Post
anybody id this?
That is a drop dead gorgeous panhead!
Do i win a prize?
"One cannot achieve ingenuity through imitation."
- Zephros Major (The Shovel Revival)
jakespade77 is offline   Reply With Quote
Old 08-25-2011, 10:38 AM   #102
SpeedAndNoise
SpeedAndNoise's Avatar
Originally Posted by calgbob View Post
SpeedandNoise...I know this one b/c I have that exact same springer with the same rockers and nuts. It's made by Butts Manufacturing. A search for Butts should turn up a couple more threads bout them.
Thanks, I didn't realize that there is on in post #40 of this thread.
And Scavenger, I've seen some kits for use with stock trees where the springs were at the bottom of each leg just above the rockers. This looks like it might use some type of fork tubes for the rear legs but even the trees look custom. The top nut isn't removable and the stem screws up from the bottom tree. The whole thing looks like it can be disassembled down to the legs. Even the rocker mounts look like they might screw off (I haven't tried).
SpeedAndNoise is offline   Reply With Quote
Old 08-25-2011, 04:45 PM   #103
carbineken
I've got one of those too. The entire thing can be broken down, the rocker mounts will screw off the legs. The top nut is loose from mine, was like that when I bought it but looks like its a press fit to the top clamp. Look through the my pics in this thread, its almost entirely apart.
carbineken is offline   Reply With Quote
Old 08-29-2011, 05:46 PM   #104
panheadmark
Nobody ever identified this springer? I have just like it any ideas?
Originally Posted by twowheeledhell View Post
Directed to this thread with my identification issue-thanks in advance for your shared knowledge and time-specs are below-sorry for duplicating this mess somewhere else!!
Justen
Take a look at the pics- The measurements are below-they should be easy enough to understand.
3 3/4" between front fork legs where welded to bottom of lower spring perch.
2 3/16" center to center of spring rods
Front legs are 40 3/16" very top to bottom pivot center
Rear legs are 40" from bottom of lower tree to center of rocker pivot
Rear leg is 7 11/16" from top of bottom tree to very top of rear leg/top of upper tree clamp area.
Space between middle spring perch/support and top of lower tree is 4 3/4"
Upper tree is 1/2" steel-the stem hole is 1 1/8" in the top tree.
Lower tree is 1/2" steel-stem hole is is 7/8" in the lower tree.
Riser centers are approx 2" on center
Rear legs have approx 4 1/8" between centers
Front legs are 3/4" diameter; Rears are 1 1/4" diameter
Front and rear rocker pivots is 2 1/2"
Approx 5 5/8" between inside faces of rockers at even spread top to bottom (this axle is really to short.
(this springer is only wide enough to fit a 1.6" or 1.85" rim. The one in the pics is 18x1.6"...............I threw a 21x1.6 to check it out-the tire is the key!!!
panheadmark is offline   Reply With Quote
Old 09-04-2011, 03:40 PM   #106
akchopper
looks like butts mfg. Go back to post #95 and you'll see one very similar
akchopper is offline   Reply With Quote
Old 09-04-2011, 05:15 PM   #107
Deadsmple
Deadsmple's Avatar
Thanks akchopper I think you're right.
Deadsmple is offline   Reply With Quote
Old 09-06-2011, 12:48 PM   #108
BIGASSWHITEBOY
BIGASSWHITEBOY's Avatar
Anyone recognize this narrow springer. Its on chopped 54 Pan frame currently. It looks very well built and strong. Thanks, J.
ID:	67725   Click image for larger version
BIGASSWHITEBOY is offline   Reply With Quote
Old 09-06-2011, 01:44 PM   #109
littlebike
littlebike's Avatar
Looks like Fury rockers, and such. Look at post #20,
WWILD..
"If you can't afford to do it right, the first time,..what makes you think you can afford to do it twice".shovithead
littlebike is offline   Reply With Quote
Old 09-08-2011, 04:05 PM   #110
Bodyworx
Bodyworx's Avatar
Saw this advertised on a bike for sale on CL. I have never seen anything like it but i kinda dig it. Any ideas who made it? No response from the seller yet.
Bodyworx is offline   Reply With Quote
Old 09-08-2011, 04:55 PM   #111
bostonmike
bostonmike's Avatar
picked up this springer and it looks alot like a devers wishbone, got some more pics if anyone has any ideas
mike
www.bostonmikes.com
bostonmike is offline   Reply With Quote
Old 09-08-2011, 04:58 PM   #112
hdshovel82
hdshovel82's Avatar
pretty sure that came from IL by paul cox.its pretty pricey.i saw it on ebay a while back
hdshovel82 is offline   Reply With Quote
Old 09-08-2011, 05:33 PM   #113
Bodyworx
Bodyworx's Avatar
The current owner finally emailed me. He said "It was made by Keino of Keino cycles in new York .. Former employee of indian Larry "
http://www.keinocycles.com/index.php
All i know is it gives me wood.
Old 09-08-2011, 11:41 PM   #114
deadman13
Send a message via AIM to deadman13
hey guys, do i have what i think is a fury springer. i know im missing the correct stem bolt, but i have no idea how to either get the damn thing over the rear legs and how to mount some bars to this thing. help!!
deadman13 is offline   Reply With Quote
Old 09-09-2011, 02:59 AM   #115
Zeeman
Zeeman's Avatar
Rockers look different to a Fury. But pretty similar springer. You're missing top tree and nut to attach stem.. and the risers screw in to back legs to attach bars.
Zeeman is offline   Reply With Quote
Old 09-09-2011, 03:04 AM   #116
deadman13
i have the top thing (it definitely isnt a clamp, solid block with 3 holes)
mu issue with the whole deal is i thought this was supposed to slide down over the rear legs. this wont (holes on the top plate are smaller and slightly off center it seems than the rear legs) at all.
i have a nut that can work, but heres issue #2....theres nothing for risers to screw into.... if you look in the bottom pic here, youll see the top of the legs. theres about a 1/4" lip inside about 1/2" down.
Old 09-10-2011, 05:50 PM   #117
douglas69trump
Deadman, it looks like i have the same front end. The rockers are different, but the rest looks the same. It also looks like the top piece you have is not correct. Here are photos of my setup, not the best looking but it works and is safe.
The risers bolt onto the top piece and the bolt heads fit into the springer legs. Then the assembly is held down with the center nut, which fits down into the top piece and has a lip on top. My top piece has two holes that are to be ignored, they were there when I got it.
The two nuts under it hold the front end on the frame, allowing to bars and top to come off independently.
The only stamp I have on this is an E stamped on the back of the lower piece.
douglas69trump is offline   Reply With Quote
Old 09-10-2011, 11:51 PM   #118
deadman13
how wide is the bolts on the headlight bracket? mines fucking 1" c2c
Old 09-12-2011, 06:47 PM   #119
douglas69trump
On mine it's about 3/4".
They were seized in and a hole was drilled through the same piece (top to bottom) to mount a different bracket.
Old 09-12-2011, 08:49 PM   #120
deadman13
you got any idea as how i can mount a dual headlight on there? or is there a ready made bracket?
Tags
identification, springer
