#21 |
Well this is handy...Thinking D&D or Paughco. No marks other than the serial number. Anybody know what I got?
Sponsored Links | |||
#22 |
D&D always pretty easy to spot, i have only seen the rear legs like that on the D&D springers
#23 |
Only Jammer (not Paughco) offered the twisted front legs on the D&D springers..
So it's a Jammer you have there.. |
#24 |
Ive seen lots them rockers before if you follow ebay springer site you see what I mean,Any one with skill could have twisted them legs,Ill try to get over to fryn pans and check one hes got them same rockers and twisty legs.Peace
#25 |
OK....Lets try this here. Any idea what this springer is?
#26 |
A couple close ups....
#27 |
southernfried, I'm not an expert by no means but by the simplicity of that springer it is highly possible it's a home brew.
#28 |
Southernfried homebrew,Like Link-Belt I agree,Their is some parts that look to from a couple different builders,Rockers may have been Amen but looks like tip or end was ground off,or was refabed simalair to that,and then the rocker nuts look like there from AEE,and top triple tree new refab job,legs new refab or clean butchered old stock.Hope pics help.
#29 |
Southernfried ah one more pic ah look at rocker made mistake ti last mess about rocker style check it out.Peace
#30 |
Thanks for the replys. I'm trying to decide which way I'm going to go with this project. Not sure I'm going to stay with a long fork.
#31 |
Directed to this thread with my identification issue-thanks in advance for your shared knowledge and time-specs are below-sorry for duplicating this mess somewhere else!!
Justen Take a look at the pics- The measurements are below-they should be easy enough to understand. 3 3/4" between front fork legs where welded to bottom of lower spring perch. 2 3/16" center to center of spring rods Front legs are 40 3/16" very top to bottom pivot center Rear legs are 40" from bottom of lower tree to center of rocker pivot Rear leg is 7 11/16" from top of bottom tree to very top of rear leg/top of upper tree clamp area. Space between middle spring perch/support and top of lower tree is 4 3/4" Upper tree is 1/2" steel-the stem hole is 1 1/8" in the top tree. Lower tree is 1/2" steel-stem hole is is 7/8" in the lower tree. Riser centers are approx 2" on center Rear legs have approx 4 1/8" between centers Front legs are 3/4" diameter; Rears are 1 1/4" diameter Front and rear rocker pivots is 2 1/2" Approx 5 5/8" between inside faces of rockers at even spread top to bottom (this axle is really to short. (this springer is only wide enough to fit a 1.6" or 1.85" rim. The one in the pics is 18x1.6"...............I threw a 21x1.6 to check it out-the tire is the key!!! |
#32 | |
![]() Quote:
Bob |
#33 |
Not sure but I do like it.Peace.
#34 | |
![]() Quote:
Thanks for the info,,was not aware of that
Du doch nicht! |
#35 |
no numbers no name. Any idea?
HOLD FAST!!!!!!! " I hate to advocate drugs,alcohol,violence, or insanity to anyone but they've always worked for me." HUNTER S. THOMPSON |
#36 |
I recently seen a Dislong Springer on Ebay is gone now. It had simailar look 2 yours but total different rockers.need more pics of triple trees and around spring area.Ill keep my eye open if I can figure it out another one more down hundereds 2go.Peace Brother.
#37 |
Have Garage Find Springer? Was Custom Made by Someone? No Markings or Numbers. Any Ideas. Came from Estate sale Ossining,NY.Included in this sweet deal Chrome Frame with the name(HARRY) stamped on back bone.No I didn't get that information,only some cool parts. I did hear that this guy was a Master Artist of ?? unknown of what he did ? Any information is good Brothers.Peace
#38 |
Not a bad deal for the price. Springer looks homemade to me, although similar to paughco.
Did you find out anything about the other bikes she had for sale? |
#39 |
I think that bike came from the same place that Sprglde talked about in the hoards thread here:
https://www.jockeyjournal.com/forum/s...ghlight=hoards |
#40 |
New here and looking forward to learning as much as I can. Here's my springer. Picked it up for a bill. Not sure if I'm ever gonna get around to using it but would like to know what it is. I've searched and haven't seen another like it.
Tags |
identification, springer |
Display Modes | |
