The designated springer ID thread - Page 14 - The Jockey Journal Board
Old 09-23-2012, 11:16 PM   #261
TheAppleKnocker
TheAppleKnocker's Avatar
Default Re: The designated springer ID thread
Check this out
https://www.jockeyjournal.com/forum/s...pringer&page=3
Schuchert Motor Sales
BLOG: chopper catalogs and magazines
TheAppleKnocker is offline   Reply With Quote
Old 09-24-2012, 02:19 PM   #262
348
348's Avatar
I've had this for awhile and would love to find a top tree for it. Any ideas on what it is or where to find the tree?
348 is offline   Reply With Quote
Old 09-25-2012, 11:46 PM   #263
CoreyVanDine
CoreyVanDine's Avatar
Trying to figure this one out.
Photobucket Pictures, Images and Photos
CoreyVanDine is offline   Reply With Quote
Old 09-26-2012, 07:56 PM   #264
CoreyVanDine
Old 09-28-2012, 08:57 AM   #265
Scavenger
Scavenger's Avatar
More of a , What was it , springer, lol Stamped IV HD on bottom of legs
Du doch nicht!
Scavenger is offline   Reply With Quote
Old 09-28-2012, 11:31 PM   #266
750 REAPER
750 REAPER's Avatar
[QUOTE=83shuvluv;828643]I was told this was an old Donnie Smith but not 100% sure. Let me know if you have any other thoughts on it please.
[/QU
i have this same front end...im needing some info on where (if possible) i can find the top tree... like the one in the second pic
750 REAPER is offline   Reply With Quote
Old 09-29-2012, 11:09 AM   #267
worn
worn's Avatar
It's an SBF springer (Smith Brothers and Fetrow).
ID:	79484   Click image for larger version
worn is offline   Reply With Quote
Old 09-29-2012, 12:02 PM   #268
750 REAPER
750 REAPER's Avatar
thanx for the reply..... after doing some research iv gathered that SBF is no longer around...im just curious if anyone has a top tree or if another company makes a reproduction...OR am i better off fabing one
Old 09-29-2012, 03:09 PM   #269
iflybyu
Looking for a little help IDing this springer..
Thanks
Mike
iflybyu is offline   Reply With Quote
Old 09-30-2012, 04:08 PM   #270
SpeedAndNoise
SpeedAndNoise's Avatar
That's a Columbus. There are a few in this thread.
SpeedAndNoise is offline   Reply With Quote
Old 09-30-2012, 08:00 PM   #271
iflybyu
\Are they or were they any good?
Old 10-02-2012, 09:40 PM   #272
Racepres
Racepres's Avatar
Originally Posted by Danny F. View Post
Just for the record...
DNA = Do Not Attempt
(Not my bike)
Exactly what my fears are!!
I have what seems to be a stock H-D springer.. except that it measures 29 inches from the top of the bottom tree [bottom bearing] to the axle, at rest.
I'm guessing 6" over!
So.. How/where would the modification be found???
If I'm not making this clear, I can take pictures tomorrow.
Thanks in advance.
RP
Racepres is offline   Reply With Quote
Old 10-03-2012, 11:03 AM   #273
Racepres
Racepres's Avatar
OK here is a couple of pictures.
Where would one look for the modification to make this F.E. longer? I want to check for build quality. I suspect that it was slugged at the point[s] circled in red.
What to look for??
Thanks
RP
ID:	79616   Click image for larger version
Name:	Spr lenth copy.jpg
Old 10-03-2012, 11:08 AM   #274
TheAppleKnocker
The FE is just a casting number. It looks like they extended the legs at the top
Old 10-03-2012, 11:14 AM   #275
348
348's Avatar
Any ideas? Anyone?
Old 10-03-2012, 01:02 PM   #276
Racepres
Racepres's Avatar
Thanks AppleKnocker;
Probably at this point where they apparently molded the joint also.
Odd that it would get modified at the oval portion vs the round part [at the bottom] But.... Guess I won't know unless I strip the thing Huh?
Still is it worth 200 ?? Or run away??
RP
Old 10-03-2012, 01:07 PM   #277
VonWegener
VonWegener's Avatar
What to look for??
Thanks
RP
When I look at a springer I check the rear legs first. Its a little hard to tell from your pics but the rear legs are round and taper towards the bottom?
At any rate the rear legs are attached to the original harley lower triple tree with what I assume is a slug and a lot of brass.
Not uncommon and can be sturdy as hell.
The front legs are really nicely extended and I would assume that the same person did the rear legs too.
I would leave it as is. It can never be original again and looks like a quality piece as is.
JUst saw the extra pic. $200 is a good deal.
VonWegener is online now   Reply With Quote
Old 10-03-2012, 03:13 PM   #278
Racepres
Racepres's Avatar
Thanks for that VonWegener.
RP
Old 10-13-2012, 11:05 AM   #279
FilthyLuke
I thought this was a Columbus based on the design of the rockers but Sixball informs me that's not so because its welded. Can any of you assist? I've been through the thread several times. There are no stampings/markings anywhere on it. My apologies for the fuzziness. If you need more details I can take more pics tonight. Thanks!
FilthyLuke is offline   Reply With Quote
Old 10-16-2012, 07:16 PM   #280
Taylor623
Taylor623's Avatar
Anyone have any ideas of what this one might be? Just picked it up at a swap this weekend. Its missing the top tree. I think its 10 over. It has some cool square springs though
ID:	79955   Click image for larger version
ID:	79956   Click image for larger version
ID:	79958   Click image for larger version
Name:	Screen Shot 2012-10-16 at 4.12.37 PM.jpg
Taylor623 is offline   Reply With Quote
Tags
identification, springer
