XLCH Kickstart Crank Gear Fit on Shaft ? - The Jockey Journal Board
Old 02-15-2019, 02:27 PM   #1
whittiger650
whittiger650's Avatar
Cool XLCH Kickstart Crank Gear Fit on Shaft ?
I am installing a kickstarter setup on my 1970 XLH. The kicker components came from a 1963 XLCH.
Test fitting the components before assembly revealed some burs that I could readily see which were what I thought was contributing to what seems like a hard interference fit.
However, after deburring the crank gear and shaft edges, it's barely better. Should the crank gear be a sliding fit onto the shaft with no interference or is it normal to have to tap it on having an interference fit, which doesn't seem right to me ?
Name:	Kicker Gear #1.jpg
ID:	253728   Click image for larger version
Name:	Kicker Gear #2.jpg
ID:	253730   Click image for larger version
Name:	Kicker Gear #3.jpg
Jon
Old 02-15-2019, 03:07 PM   #2
CookieMonster
CookieMonster's Avatar
Default Re: XLCH Kickstart Crank Gear Fit on Shaft ?
Yeah, that would be a tight fit, it should need to be knocked out with a mallet when removing.
When you get it fitted and check end play, rotate the shaft and check it in a few places.
Old 02-15-2019, 04:34 PM   #3
whittiger650
Cool Re: XLCH Kickstart Crank Gear Fit on Shaft ?
Thanks. Did you mean "should" be a tight fit, instead of "would" be a tight fit ?
Jon
Old 02-15-2019, 05:02 PM   #4
CookieMonster
Erm, both...sorry, typing / remembering in an inarticulate hurry. That engineering application ‘would’ require a tight fit to ensure that the mating surfaces do not wear and get sloppy. (Thinks hard to make sure not spouting bollocks...oh yeah, remember this now...) You ‘should’ need to knock the two apart with a mallet or brass drift. Which you might need to do several times in the near future to get end play right. Tight is good.
More to this assembly than meets the eye.
Old 02-16-2019, 06:41 AM   #5
whittiger650
I appreciate your help. Now, time to put it together.
Jon
Old 02-21-2019, 08:57 AM   #6
mlotti
Be careful the clutch spacer and sleeve and possible gear from your 69 pieces are not correct for your year bike and big trouble could result. please do your research.
mlotti is offline   Reply With Quote
Old 02-22-2019, 05:36 PM   #7
whittiger650
Yes, I did do the research. According to my parts book, 1963 parts in question are the same for the 1970 models.
Jon
Old 03-06-2019, 10:58 PM   #8
Timmy2times
Timmy2times's Avatar
Default
How did it turn out im very interested since im building a 70 xlh too my kicker gear slides right on the shaft not tight at all but doesnt have play if that makes sense
Timmy2times is offline   Reply With Quote
Old 03-07-2019, 06:54 AM   #9
whittiger650
I got stalled by deciding to buy some special tools and waiting for the last one to get here in order to put the primary back together without using bodges and the extreme cold we have had lately.
So, I should be updating soon. I feel like my kicker gear should fit more easily like yours !
Jon
Old 03-07-2019, 09:50 AM   #10
Timmy2times
Default
Im stalled out too i need to fix the clutch basket chingadera and need the thimbles for the clutch springs ive slowly been gathering what i need since my electric kick start on the 70 has a lot of 1 year parts kinda hetes what im messing with i have 2 clutch set ups 1 for the 70 and 1 for a newer wet clutch set up that im not using shovithead hooked up the stock parts for mine and steered me in the right direction (super miss that guy) but everyone here lent me a hand and helped me get my tranny shimmed right mostly through direct messages
ID:	253908   Click image for larger version
Similar Threads
Triumph crank gear removal? flypa38 The Board 35 12-17-2013 07:44 PM
Ironhead kickstart shaft question Bumpstick The Board 7 02-04-2010 07:44 PM
Kicker lever crooked with new crank gear? Jim1203 The Board 12 08-05-2008 01:02 PM
my knee hurts. xlch ratchet gear. elmcitydave The Board 4 06-29-2008 10:41 PM
Help ! Pinion gear wont set all the way in??? Richiepan The Board 1 03-19-2007 12:03 AM
