Black rims for BSA - The Jockey Journal Board
Old 11-24-2020, 03:07 PM   #1
flat-tire
flat-tire's Avatar
Default Black rims for BSA
I need to find black rims for a 1970 BSA Lighting project. 19" in front and 18" rear.
Question: will any 40 spoke 18" HD rim work? or must I find a British rim?
thanks
flat-tire is offline   Reply With Quote
Old 11-24-2020, 03:13 PM   #2
Goldy
Goldy's Avatar
Default Re: Black rims for BSA
You'll want the spoke angles to be the same...better off with the real thing. Why not paint or powder coat the ones you have? That one in the photo might even clean up well.
This too shall pass.
Old 11-24-2020, 05:59 PM   #3
^^^ Goldy gets a medal for good advice, esp about spoke angles.
If you are rich, or just robbed a gas station, Buchanan's can fix you up with correct, well-made, and beautiful stuff. Their options (alloy or steel, std. or HD spokes, finishes & colors and so forth) just about cover what's available in the wide world of wheels.
http://www.buchananspokes.com/contact/contact_us.asp
"Bite the parts like a monkey." --Dutch Dennoz
Old 11-24-2020, 07:20 PM   #4
whittiger650
whittiger650's Avatar
Cool Re: Black rims for BSA
Oh yeah, an SOS pad or two, liberal amounts of water, a little elbow grease and that rim will look pretty good
That's definitely what I would do.
Jon
And now you do what they told ya"
whittiger650 is offline   Reply With Quote
Old 11-25-2020, 07:32 AM   #5
Goldy
Goldy's Avatar
I've had great luck with a brass wire bruch followed up by the ol' aluminum foil and WD40 trick.
Old 11-25-2020, 11:25 AM   #6
Yes, good advice on the spoke angles...I forgot that I knew that. So unless money is not of concern or you just want a different rim I would also reuse, clean up or repaint the existing rims.
Old 11-25-2020, 08:36 PM   #7
whittiger650
I have had success with that too, thanks for reminding me
Jon
Old 11-26-2020, 12:18 PM   #8
0000 steel wool and Pepsi cola works well.
