Picked up a 46 U Flatty that came from South America, and I'm not sure if the frame is original. It's too perfect! Not a tab cut off, nothing butchered or welded back on. It's just too nice. I guess coming from down there in the jungle, it never got cut on and was just ridden all these 74 years. Does anyone have a sure fire way of telling an original from a high quality repop with all the casting numbers in the right places and so on. I read Palmers section on the bull neck frames and it appears to be a late 46 to early 47 frame according to his description. Any help will be appreciated.
A modern frame should be
Obvious My 39 the down tubes are beaten flat Side stand is almost worn through etc
Rush Rush to the Yayo. Blondie "Ultimately were all dead men"(Oliver Reed.Gladiator) |
a fella I bought an FXS from 4 years ago had this sitting in his garage,
it came out of South Africa & was fitted with a sidecar when he got it, but he stupidly let a 'buddy' talk him out of it for £1000 ( $1250)!, it's All traceable with Army paperwork to a contract that went to South Africa in 41 or 42,.... it is pretty much mint & all original except the rear rack he got from a 45 he owned years ago, (still an OEM part not repro),... no marks, dents dings or anything to show it's age & what he believes is just over 18000 miles under it..... sometimes ya just can't do wrong & score a great deal from overseas where the chop it up cult never started back in the day.... |
To add to Pete, I've seen a few non molested 39/40 41 frames go for 8000 dollars... be hanging on to my 40 for a long time as it's all OEM!
King or street sweeper, everbody dances with the grim reaper. |
#5 | |
Someone like Eric (SpeedingBigTwin) might be able to offer some insight, that's why I suggest posting pics.
"No one knows what they don't know." - Govmule84, Wannabe Hipster |
eric will need real clear pictures if every number on the unit close up to give you a real evaluation
i have seen unmolested frames and being from a warm area in the world rust is and should be present - no air conditioning into the late 60s / 70s for people with real money in that country
Ineptocracy (in-ep-toc'-ra-cy) - a system of government where the least capable to lead are elected by the least capable of producing, and where the members of society least likely to sustain themselves or succeed, are rewarded with goods and services paid for by the confiscated wealth of a diminishing number of producers |
Here are a couple of pic's of the frame awhile. I'll try to take some better ones, but I already had these loaded on my PC. I know they are kind of dark. I found a little bit of rust inside the seat post tube. The problem is someone started restoring it, so the frame is already painted. The tanks are original, but the fenders are not. The tranny is a 46 and matches the engine. The front end is original, but it is an inline springer, and It should be an offset, so the whole bike is a bit of a miss match. But for what I gave for it, I could not pass it up. I'm going to change the wheels back to mechanical brakes, they were going to use disc brake wheels on it. It's a project!
That looks pretty real to me BF.
If it's not it's a damn good copy! I'd say real though. If the neck is not molested, may be worth checking the rake. It should be 30 degrees for bullneck. Although there were some late 47 frames which were not bullneck and also 30 deg rake.
King or street sweeper, everbody dances with the grim reaper. Last edited by rhysmort; 10-30-2020 at 08:47 PM. |
Repop frame. All knucklehead necks were brazed up til 1947.
Wanted: Cal Products C8 transmission case https://www.jockeyjournal.com/forum/...58#post2063958 |
#11 |
It definitely looks brazed...
#12 |
Oh yea
Some nice brazing 🤣 My frame brazing is much neater 39ulh
That is really neat Rich, mine isn't that neat.
#14 |
Then maybe your repop too
Brazing doesn’t make a big booger type weld line outside fitting Even I know that (but I did study it at school)
#15 |
your dead right, Brazing leaves a real neat finish on the joints,.. I have had a few 45 frames which were all but the odd tab or bracket brazed & needed no filling or grinding to clean up before paint,..... as you say, only repops were welded, this is a brazing station at harley & you can just about see the bright braze on the joints .....
#16 | |
By far the nicest I've seen. I know it's neater than welding. I also think mine has had a few repairs. The frame I had on my UL was repop and that was really tidy too.
#17 |
Braze cannot be welded over,...
#18 |
Indeed
The plot thickens
#19 |
& as you can see here the joints all look very tidy at the factory...
#20 |
I didn't say it had been welded?
I stripped my frame down to bare before I sprayed it. I can assure you it's not welded.
