1970 Sportster Clutch M/S Nut Torque ? - The Jockey Journal Board
Old 04-02-2019, 07:01 PM   #1
whittiger650
whittiger650's Avatar
Cool 1970 Sportster Clutch M/S Nut Torque ?
I am in the process of reinstalling the clutch components and the manual says 150 ft/lbs for the mainshaft nut. That is a lot, is this correct ? Am I reading it right ?
So far I have torqued it to 130 ft/lbs but that seemed like I was really pushing it !
TIA
Jon
And now you do what they told ya"
whittiger650 is offline   Reply With Quote
Old 04-02-2019, 10:38 PM   #2
Default Re: 1970 Sportster Clutch M/S Nut Torque ?
I am almost 100% that it is correct. I know the nut on the crank is way more than that, I think 250 if memory serves.
When all else fails follow the manual. If something gives and shit breaks, it was in bad shape and a ticking time bomb and you just saved yourself a possible fiasco.
Old 04-03-2019, 02:57 AM   #3
CookieMonster
CookieMonster's Avatar
Yep, 150 on the clutch hub nut. Made a tool to do this as there is a concern the wedge type tool will damage the oil tight rivet seal on the clutch drum. The best way would be with an impact and torque bar, but that’s quite fancy. If you have a good enough ‘feel’ of your impact gun you can do it that way. Caution, too much will mushroom the kicker spacer and cause it to stick.
I think the crank nut actually less, perhaps 100? But no worries here if you overdo it, you can put a lot on before doing any damage.
I’ll look up facts and figures later if you haven’t sorted it, but there are no torque values in the FSM.
CookieMonster is offline   Reply With Quote
Old 04-03-2019, 07:02 AM   #4
whittiger650
Cool Re: 1970 Sportster Clutch M/S Nut Torque ?
150 it is. Thanks for the help.
Jon
Old 04-03-2019, 07:08 AM   #5
CookieMonster
Here’s how I held it to torque, foot peg rest stops everything turning. If you have a kicker and are fitting a new spacer you’ll want to torque up then remove to measure to work out clearance as per the manual, tightening compresses the spacer slightly.
Old 04-07-2019, 07:49 PM   #6
whittiger650
I got it torqued to 150 ft-lbs. The factory service manual does give the 150 ft-lbs setting on page 143. It actually says at least 150 ft-lbs !
Jon
Old 04-08-2019, 01:41 AM   #7
CookieMonster
Apologies if I misinformed anyone then, but I’m fairly sure my manual (‘59-70?) doesn’t but later copies do, a member here advised the value. Out of curiosity do you have a dry clutch and a kicker? The ‘at least’ part seems odd, as you can definitely do damage with too much. Glad you got it together.
Old 04-09-2019, 06:15 AM   #8
whittiger650
No worries. I will have to scan that and post it as I chuckled that it said "at least" for a torque setting !
I do have the dry clutch and the reason I had it apart was to install a kicker.
Jon
Old 04-09-2019, 07:02 PM   #9
whittiger650
Looks like my manual covers from 1970 - 1975, revised 1-75.
Name:	H-D Sportster Service Manual Page 143.jpg
Jon
Old 04-10-2019, 07:58 PM   #10
whittiger650
I found a seller on eBay who makes service tools for a decent price and here they are. Easy peasy !
Name:	Clutch Assembly #1.jpg
ID:	254202   Click image for larger version
Name:	Clutch Assembly #2.jpg
Jon
Old 04-11-2019, 03:13 AM   #11
CookieMonster
I made something similar to that tool to tighten the crank nut as I could find no other way to lock it (hindsight I should have just impacted the shit out of it), but I didn’t want to use it for the higher torque on the clutch drum in case of damaging the drum or upsetting the integrity of all the rivets I’d just sealed. I know that tool is pictured in the manual but there are lots of ways the clutch can let oil in and through those rivets is one. It didn’t take much to drill a few holes in a piece of flat bar, if it avoids taking it apart again.
Similar Threads
Clutch hub nut woes VoodooShovel The Board 1 07-26-2009 04:38 PM
sportster clutch help? jarod7736 The Board 7 04-03-2008 04:37 PM
Sportster Clutch Question 63CadGuy The Board 3 02-27-2008 10:37 PM
67 Sportster clutch cable question? El Larry The Board 5 07-12-2006 11:02 AM
'96 Sportster 1200 clutch schematics? halwade The Board 0 02-07-2006 10:28 PM
