Short Oil filter - The Jockey Journal Board
Old 07-28-2020, 08:23 AM   #1
richbob
richbob's Avatar
Default Short Oil filter
Anyone have any cross reference numbers for a generic filter see pics
ID:	257934   Click image for larger version
Old 07-28-2020, 09:02 AM   #2
Just Passin' Thru...
Default Re: Short Oil filter
not sure if generic, maybe this?, 63810-80A
edit: i found these cross reference numbers too that may work...
Fram PH6019
Fram PH6074
Old 07-28-2020, 09:21 AM   #3
magnum45pete
magnum45pete's Avatar
the tag you show is Motorcycle Storehouse number, it is for 80-E84 XL, L82-84 FL & FX & it replaces 63782-80 & 63810-80A
https://www.motorcyclestorehouse.com...ex.html#zoom=z
Old 07-28-2020, 09:25 AM   #4
[JP]
[JP]'s Avatar
part no 580471 in motorcycle storehouse
I usually get them off ebay, most of the times listed for generic use - triumph.
Instagram - JPINTHEUK
Old 07-28-2020, 10:05 AM   #5
richbob
richbob's Avatar
Default
Thanks men
I found this on net .it just took me 3 weeks to get Yorkshire tea (loose leaf) from uk
And I’ve never entered a stealership
(As I hear There called)
I’m testing the locals (Car parts store)to come up good
It’s m16 and it’s critical it’s less than 165mm long
ID:	257940   Click image for larger version
ID:	257942   Click image for larger version
Old 07-28-2020, 11:08 AM   #6
joe49
joe49's Avatar
Another cross reference for you.
https://www.oilfilter-crossreference...IDSON/63782-80
OLD MOTORCYCLE ENTHUSIAST
Old 07-28-2020, 11:15 AM   #7
magnum45pete
I use the same one on my JBROSG oil pump filter cover or the longer ones would hit the transmission....
Old 07-28-2020, 11:46 AM   #8
govmule84
Forum Dipshit
That fucking filter drives me batshit because I can't ever find a good automotive replacement.
If someone comes up with a good cross (even if it's longer!) I'd be indebted.
Old 07-28-2020, 12:11 PM   #9
im not positive but this might be worth a try
https://www.napaonline.com/en/p/FIL7013
Old 07-28-2020, 12:25 PM   #10
Dutch Dennoz
Dutch Dennoz's Avatar
I had to use a mann w75/3 filter to get it inside the primary cover...dia 76 , length 53 mm.
If you canít fix it..do it anyway.
Dutch Dennoz is offline   Reply With Quote
Old 07-28-2020, 12:28 PM   #11
richbob
richbob's Avatar
Default
Dutch short is cool and can go fatter
Sounds like porn but same thread ?
Old 07-28-2020, 12:30 PM   #12
Dutch Dennoz
M22*1.5 , i was a bitt surprised by the m16 ..not very common but easy to x-over with a reducer ring
Old 07-28-2020, 01:36 PM   #13
richbob
richbob's Avatar
Default
Yea enlarger ring
(Were going up yea?)
Then I got to find that which is a trawl round plumbing shops
Old 07-28-2020, 02:41 PM   #14
Dutch Dennoz
Enough hits on the net ..perhaps you have to grind down the hex thickness a bitt or just loose it completely.
Old 07-28-2020, 02:44 PM   #15
Dutch Dennoz
Sorry for the shady picture....adapter is the key word to search for.
Old 07-28-2020, 03:12 PM   #16
richbob
richbob's Avatar
Default
Yea I did that on a trump remote filter
I’ll see how I go I’m trying to avoid online
But I’m thinking maybe impossible
Old 07-29-2020, 08:20 AM   #17
richbob
richbob's Avatar
Default
Ok
Spent all morning hunting
Found your filter Dutch (Renault Clio)
Stumped on the adaptor some guy can make one but.
Then found A shop
Sů solution is buy adaptor online (its 20mm not 22)
Ordered the Harley filter For this oil change then next change I convert once I’ve checked specs on Mann filter
Just ordered the ring £1.74 from china (free postage) just have to wait a month to get it
ID:	257964   Click image for larger version
Old 07-29-2020, 11:54 AM   #18
joe49
joe49's Avatar
While you're looking at that other filter you should check it's specifications. The reason you use a interchange is to get the same micron and if a bypass, which these filters are, the same bypass pressure. Just making it fit could come back and bite you in the ass.
https://www.wixfilters.com/Lookup/Pa...px?Part=219335
Old 07-29-2020, 02:11 PM   #19
richbob
richbob's Avatar
Default
Exactly joe
Was looking for that info convert psi ?
Old 07-29-2020, 02:20 PM   #20
Dutch Dennoz
Good one Joe , isn’t there anything you don’t think over.
The filtration rate is 9 micron, compared to 20 on the one you linked , the bypass is way higher but being honoust i did not Thought that would be a problem..before i knew the filtration rating
