50fl - The Jockey Journal Board
Old 11-17-2017, 03:51 PM   #1
Just Passin' Thru...
Default 50fl
Where do I start.... I broke my single loop frame. As soon as my Triumph's good to go... its on!
Old 11-17-2017, 03:56 PM   #2
VonWegener
VonWegener's Avatar
Default Re: 50fl
I'm glad that you can take it with a smile Howard.
Old 11-17-2017, 04:23 PM   #3
Default Re: 50fl
It's got a crack under the neck halfway around the down tube, good thing it has a gusset there. I'm taking it with a smile cause I found the crack before it broke all the way or even worse out on the pavement.
Old 11-17-2017, 04:51 PM   #4
Default Re: 50fl
Here's my plan as of now. Use a different frame, oil tank and front end.
Old 11-17-2017, 05:07 PM   #5
VonWegener
VonWegener's Avatar
Default Re: 50fl
Have you thought of a Paughco? Especially when molded they got the look.
Old 11-17-2017, 07:17 PM   #6
Default Re: 50fl
I'm thinking about a wishbone frame.
Old 11-18-2017, 09:48 AM   #7
Default Re: 50fl
Keep off the crack pipe kids.
Old 11-18-2017, 01:04 PM   #8
JAWS
JAWS's Avatar
Default Re: 50fl
Why did you know to look for one there?
Old 11-18-2017, 05:52 PM   #9
Default Re: 50fl
Last week I rode the bike to a friends house, parked it, then came back out to show them something on the bike when I noticed the paint up there had a slight crack/flake going on so I looked at the other side and it was the same thing. I got a screwdriver and scratched off the paint and there it is. I rode the bike home very easy....
Old 11-20-2017, 06:51 PM   #10
Default Re: 50fl
This is my new frame & front end to switch everything over too. I'm going to put a Harley Breakout 21" black mag up front, other than
that not much should change but that's easy to say at the present time.
Old 11-20-2017, 11:14 PM   #11
JAWS
JAWS's Avatar
Default Re: 50fl
Good catch. Dont do that again!!
Old 11-21-2017, 09:27 AM   #12
Default Re: 50fl
I'll try not to break this one. Here's another pic, I need to leave this alone & finish up the Triumph.
Old 11-27-2017, 04:13 AM   #13
panhead_pete
Default Re: 50fl
Please post any mods you do to get the break out wheel to fit. I have a non JJ friendly evo wide glide and want to go front mag with it.
Thanks
Pete
Old 11-27-2017, 09:02 AM   #14
Default Re: 50fl
No problem, You got it Pete. I've always wanted that front wheel after seeing pics of them. Usually with mag wheels either you love them or hate them. When I seen the wheel/rim in person a few days ago I did not realize how wide the rim is.... It's wider than my 18" rear rim and tire so i'm back on the fence about using it cause it might look like a steam roller....
Old 11-27-2017, 10:12 AM   #15
2Loose
2Loose's Avatar
Default Re: 50fl
I wonder what would cause that frame to crack like that right there? Just seems really odd. And the left side seems in a bit different location than the right side, at the sugar mill where I used to work we had special equipment to check out cracks like that, but the mill shut down recently, no access to equipment like that any more !! It should be repairable though, don't toss the frame....
Old 11-28-2017, 06:23 PM   #16
Lightbulb Re: 50fl
I'm going to keep the frame here for repair some day, one less Motor Shop Frame on the road now. The new frame looks like a 49 so the 50 motor will be at home in it. The Springer is from a 45 with its 7/8 stem.
Old 11-28-2017, 07:30 PM   #17
Default Re: 50fl
There is a good chance this will be used to replace the round oil tank...
Old 11-29-2017, 10:34 AM   #18
iiggii
iiggii's Avatar
Default Re: 50fl
Like that oil tank.
CornBread mafia...
iiggii is offline   Reply With Quote
Old 11-30-2017, 06:32 PM   #19
Default Re: 50fl
^ Its very clean on the inside. ....Most of you know what the bike looks like but here's a pic for the thread if you don't. I'm gonna start stripping it down next week. Should the new frame stay orange? That is the question in my mind....
Old 11-30-2017, 09:23 PM   #20
vinlesposito
vinlesposito's Avatar
Default Re: 50fl
Daaaamn thats the first time I've seen the bike. I love single tube frames, that looks super sporty.
As a red bike owner, I say leave it orange! Its funky
72 Triumph TR6R
61 Triumph Bonneville
69 Shovelhead/53 Wishbone
