Thread Tools | Search this Thread | Display Modes |
#1 |
Hello once again...
As many know, I am rebuilding an old panhead with a Triumph TLS front hub off a '68 Bonnie. That's the "one year only" TLS front they used with the cable stop at 7 o'clock vs the 12 o'clock ones later. The construction appears to be a thick cast outter drum section (which carries the load of the braking force through the spokes and to the ground, which is why its the beefier bit I imagine) with two hemispherical sections riveted to it to make the center of the hub body (carrying the bearings, etc). The issue is that between those two dishes, there seems to be a lot of crap stuck in there. As I move the wheel around it sounds like sand sliding around or just like a rain stick. Everyone loves pictures: Left hand side of the hub, you can see the rivets from the center section attaching to the thicker outter body. ![]() Right hand side (As I unlock the bearing retainer with a little heat). Here's also the braking surface. ![]() I imagine that its not a great thing to have that junk in there and would possibly like to get it out for nothing else but my own OCD sanity. But... Options: 1) leave it there and don't mess with it. 2) get it out. Now, sub options of option 2: 2.1) Drill speed holes in one side of the plates and shake it empty... while weakening the structure and adding in style I'm not necessarily after. 2.2) Grind off the rivies and really clean it out. This is the most theoretical part. I am only assuming this is how its constructed. Ive seen people do similar things to option 2.2 with juice drums, replacing the riveted sprocket rings with a zillion little properly-sized machine screws or bolts with LOTS of locktite. This appears even easier because there's really no torque needing to be transferred through the plates, other than drag off the axle bearings the the linear loads of the ground pushing back through the tire to the frame... (I think anyway) I should mention once again that I assuming certain parts of what the inners of this wheel will look like if it were to come apart. More definitive info on that would be great. Thoughts?
IG @eric.the.beard |
Sponsored Links | |||
#2 |
I like option one to just leave it alone. You can tell yourself that that is the best option because the loose particles would help balance the drum just like balancing fluid in tires does.
To improve the looks turning down the diameter of the backing plate does wonders.
* Your friendly neighborhood W&W Cycle Germany, Paughco and V-Twin dealer |
#3 | |
![]() Quote:
![]() And I am still putting together my "make it realllllly pretty" list of to-do's for the front. There are still some crusty elements in general, especially that left side if I don't run any sort of pie plate covering the raw hub... maybe paint? But I'd still like to keep the right side backing plate that lovely raw cast aluminum look...
#4 |
The '66 and '67 models have more attractive pie plates than the '68 which is a styling disaster. And you are the master of your kingdom when it comes surface finishing
#5 | |
![]() Quote:
The 68 has three lil set screws at the hub perimeter.
#6 |
I do not know about the pre 66 hubs that have the spokes come through the drum but the '66 and newer drums with the flange on the backing plate side all share the same size on the left although the earlier ones are crimped on. I never had a hub with set screws but then I never owned a stock '68 or newer..
#7 |
Interesting.
FYI you can see the set screws in the pic above at about 3, 7, and 10 o'clock.
#8 |
Yeah I never have seen these screws. Maybe they aren't original?
#9 |
i dont think their original, either. I`v rebuilt a couple/3 of those and have never seen them before, but i`v also never had a hub that had anything except dried grease in there either! Once the bearings were out and that void rinsed clean w/acetone i would think that a suction hose equipped blowgun would suck anything not supposed to be in there out!
Originally Posted by cmantle1 https://www.jockeyjournal.com/forum/h...s/viewpost.gif yea Newtons fourth law says mass x triumph engine x pavement = the need for head steadies!? haha ![]() http://www.ace-custom.com/ https://www.facebook.com/acecustomcycle |
#10 |
+1 on the non-original screws. I've got a wheel apart now from a '69 that was just crimped. (OK, it's from a BSA, but it's the same wheel for those years.)
In theory there is no difference between theory and practice. In practice there is. Yogi Berra |
#11 |
agreed, '68 wheel i have does not have the (3) screws.
RUN FOR YOUR LIFE Mother F*cker!!!! August 4-7, 2016!!!!!!!!! Random Chopper Goodness at the link below.... http://r4yl.blogspot.com/ |
#12 |
Fair 'nuff. Thanks for the input guys!
I think the existing hub side has a date with the wire wheel and some paint... If I wanted to disassemble the wheel to get access to all surfaces for a cleanup and paint job, is the reassembly something reasonable to do in a basic shop without any real experience? Especially the tensioning/trueing process.
#13 |
Around here having a wheel assembled and trued is around $40. I am sure it will be close to that in Seattle. So that is your monetary gamble. If you disassemble the wheel it will be a lot easier to clean and polish the spokes and nipples.
Plus it does not hurt to know how to lace and true a wire wheel.
#14 |
Don't be intimidated by wheel building. Theres some good info on the web.
Get the correct spoke set, take some pics and measurements before disassemble And a quality spoke key.
Rush Rush to the Yayo. Blondie "Ultimately were all dead men"(Oliver Reed.Gladiator) |
#15 |
#16 |
That's a double walled affair with a space in between full of rust debris...Drill two half inch holes 180 degrees apart and blow out the debris...
You can see in this photo during my recent T120 build how I left off the cover and drilled the front hub for a "racey" look..The inside wall prevents seeing the brake shoes... ![]()
I ride junk,some of it is fast |
#17 | |
![]() Quote:
#18 |
Thanks for the tips. Are you saying that I should rebuild with new spoke sets or is reusing the ones with the existing built wheel an okay practice?
#19 |
depends how Brassic you are
I would buy stainless new butted.(but thats me)
#20 |
Drilling two small holes or even a group of large ones won't affect the strength...
Display Modes | |
