Anybody use the James Super Nut? - The Jockey Journal Board
Old 02-16-2018, 03:39 AM   #1
curtisvitoria
curtisvitoria's Avatar
Default Anybody use the James Super Nut?
Im in the process of rebuilding my 4spd for my 1950 Pan, I have a 47 knuckle 4spd in nice shape that I'm rebuilding. Is this nut worth the $30?
Ive read some spacing issues may come up due to the nut being twice as thick. Curious if anyone has been down this road? I should also mention I am running a Primo pro clutch with the big sealed bearing in the hub.
Name:	Screen Shot 2018-02-16 at 12.35.32 AM.jpg
curtisvitoria is offline   Reply With Quote
Old 02-16-2018, 04:42 AM   #2
Default Re: Anybody use the James Super Nut?
I tried using that and had the spacing issues, so didnt use that but did use that other bit with the groove and o-ring, made by that dude in Canada..
sorry, not making much sense, just woke up and brain is not fully engage yet lol
Old 02-16-2018, 06:37 AM   #3
Custom Chrome uses them on their transmissions as new.
I see them as a bit of a bandaid when used to stop the fourth gear/main seal leak, but don't have any issue with seeing 'em on a newly rebuilt trans.
That Canadian dude might be somewhat hard to find. I published his name here a while back and he asked it be taken down.
The spacing issue is a pain in the ass if you're attempting to use a mainshaft bearing support on a Shovel.
You may also be interested in this item: https://shop.bareknucklechoppers.com...e-overbearing/
Old 02-16-2018, 09:32 AM   #4
Samhain
Samhain's Avatar
Search shovelhead leak on that auction site and there's that Canadian guy....
Samhain is offline   Reply With Quote
Old 02-16-2018, 12:52 PM   #5
curtisvitoria
k thanks for the info, searched and nothing
Old 02-16-2018, 12:53 PM   #6
New bushing installed in the main direct gear and the stock seal works fine. You did say you are rebuilding it.
Old 02-16-2018, 01:18 PM   #7
Samhain
Samhain's Avatar
I can get the search to pop up, first hit.
New bushings fit worse than what was in there before in my experience. Get the mainshaft cleaned up, and have a bushing made, then reamed to fit after being pressed in, then they are still designed to leak.
That Canadian guys fix is pretty good and easy, my mainshaft had a step right where the oring landed though and wasnt ideal. I Should have paid more attention before putting the oring groove in.
Old 02-16-2018, 03:12 PM   #8
The ebay is a copy of the 1984-up spacer 35070-84 the oring is 11166. Still available and at lower cost.
Also available on Amazon in Eastern brand for less than 1/2 the ebay one.
Old 02-16-2018, 03:49 PM   #9
Another neat trick which I used on mine on the mainshaft are exact match ID rubber orings. My 4 speed has new seals and 2 orings on mainshaft. Doesn't leak at all now.
Old 02-16-2018, 08:23 PM   #10
curtisvitoria
Found him and ordered one!!!!! Thanks for all the information!!!!
Old 02-18-2018, 05:33 PM   #11
saddlebagrail
Default spacer with o-ring for leaking tranny
spacer with o-rings are acually 50 dollars US icluding shipping to North America sligthly more outside NA,you could contact the guy direct in Canada
[email protected]
saddlebagrail is offline   Reply With Quote
Old 02-20-2018, 09:03 PM   #12
curtisvitoria
Thanks Saddlebag, I got one from you!
