How to make a new paint job check/crack (on purpose) - The Jockey Journal Board
Old 11-08-2017, 07:26 PM   #1
kbb
kbb's Avatar
Default How to make a new paint job check/crack (on purpose)
I’d like to get a checking (or wrinkling or cracking) effect on a Triumph tank I’m about to paint. I want to create the conditions for it to happen naturally (but quickly) if possible instead of doing an actual faux-finish.
Any thoughts on how I could make this happen to a new finish?
Chemical reaction? Shrinking paint? Expanding metal?
What type of paint was most susceptible to checking back in the day?
Name:	Screen Shot 2017-11-08 at 4.19.39 PM.jpg
ID:	244353   Click image for larger version
Name:	Screen Shot 2017-11-08 at 4.20.09 PM.jpg
ID:	244361   Click image for larger version
kbb is offline   Reply With Quote
Old 11-08-2017, 07:30 PM   #2
kbb
kbb's Avatar
Default Re: How to make a new paint job check/crack (on purpose)
Here are some checking catalysts I found online, no way to vet these besides testing:
Solvents in new finish attacking old finish… ex) painting lacquer clear over urethane/enamel base.
Recoating single stage outside of the flash window.
Heavy, wet basecoats, sprayed over with finish coat.
Hard/inelastic paint.
Expansion/contraction of metal or paint.
An idea related to expansion: I could paint the tank cold (how cold?). After the paint is hard, I could heat up the tank from inside to expand the metal.
My understanding is that acrylic enamel will dry harder than lacquer, but it takes a while. Not sure where a single stage urethane (with hardener) lies on that spectrum. I need something almost brittle I think.
Old 11-08-2017, 09:08 PM   #3
bobscogin
Most older paints that have cracked are lacquer. Lacquers are applied with a high percentage of lacquer thinner as the "vehicle" which carries the solids and pigment. They dry only through evaporation of the solvent over time. Because of this, the paint losses a lot of it's original volume, shrinking in the process. There are modern decorative painting processes which can simulate the cracking but I don't know if they're suitable for automotive use.
Bob
Old 11-08-2017, 09:54 PM   #4
Ratso
Ratso's Avatar
Agree. To my knowledge, lacquer is the most crackable paint. Heat and freeze the tank over the course of ... um ... a week? I dunno.
My '47EL was painted in lacquer, as custom bikes chiefly used to be I believe, and it was most excellently crackled.
Old 11-09-2017, 12:50 AM   #5
kbb
kbb's Avatar
Copy that. I'm gonna buy a tank to test with.
Maybe my first attempt will be lacquer, and possibly find some way to get rid of the solvent a bit more abruptly... plus temperate abuse.
Old 11-09-2017, 06:04 AM   #6
magnum45pete
magnum45pete's Avatar
Back in the 70's I played with a Custom paint called VREEBLE that gives this effect real easy and I was surprised that it looks like it's still available as I found this Video on it,.... it has an email address at the end for the supplier.............. a similar effect can be had spraying cellulose over enamel but effect is less predictable, slow & messy....
Old 11-09-2017, 09:02 AM   #7
zedboy
zedboy's Avatar
Paint it, lacquer it, give it a chance to set up a little & then wipe it down with a rag with some thinners on it.
zedboy is offline   Reply With Quote
Old 11-09-2017, 09:13 AM   #8
bobscogin
The more solvent you put in it, the more likely it is to crack. It will also run more easily, but you can sand out the runs if that bothers you.
Bob
Old 11-09-2017, 10:42 AM   #9
govmule84
Forum Dipshit
That Vreeble is nifty, never seen that before. Doesn't look like checking to my eyes, but it is cool!
Old 11-09-2017, 11:02 AM   #10
rhysmort
rhysmort's Avatar
I powder coated mine, then rattled following by lacquer. Cracked like a motherfucker! powder and paint don't get on which has added to it!
rhysmort is online now   Reply With Quote
Old 11-09-2017, 12:17 PM   #11
Dan Boy
Dan Boy's Avatar
Its called "crackle paint", plenty via google.
Blown Triple Build
Old 11-09-2017, 12:45 PM   #12
cajun
I'm 63 and spent my entire life trying to make things look polished and glossy. Always amazed at people doing just the opposite. Free world and free will so do your thing. Some of it can be pretty convincing.
cajun is offline   Reply With Quote
Old 11-09-2017, 01:08 PM   #13
magnum45pete
I know what you mean,...
Kids today cant be bothered to make something look nice or ''waste'' the time in keeping their bikes clean hence the FAKE patina look has been used as an excuse for ''kool''.
back n the 70's, Vreeble was used for the cracked effect in Murals and in panels and panel edges that was then flatted and lacquered smooth as a baby's backside, then pin striped around as a highlight
it was NEVER used to fake age of a bike or Rod.......
fake is fake and always will be,...
only way to get that look if you want it is to do the job right in the first place THEN use it for years without cleaning it,....
eventually you get the look by earning it,... not painting it.
Old 11-09-2017, 04:19 PM   #14
kbb
kbb's Avatar
Lol, are you done?
I'm trying to avoid paying period-correct tank prices for a period-correct bike. Not going to do a full restoration on this bike to aesthetically match a new paint job just because some blowhard on the internet thinks it's "fake". I think I see some kids on your lawn, if you need someone to yell at.
Old 11-09-2017, 04:21 PM   #15
kbb
kbb's Avatar
Bob
Lots of good suggestions coming in... Time to experiment. Thanks everyone.
Old 11-09-2017, 04:33 PM   #16
flatford39
Shoot lacquer over an enamel base and it will crack immediately.
flatford39 is offline   Reply With Quote
Old 11-09-2017, 04:57 PM   #17
shovithead
shovithead's Avatar
Bingo, give the man a star by his name. the enamel needs to sit overnight, to create a shell on the outside. Then shoot the lacquer. Only drawback is the enamel will take a week to cure, if it does it that quick. It has to have a heavy coat of enamel, so it does take time to cure overall.
42 UL long term project
51 FLH short term project
60 Doc Dytch XLCH Drag only
61 XLCH parts bike
65 XLCH parts bike
66 FLH
68 XLCH parts bike
69 XLH wifies bike
69 XLH daily rider
70 XLH
72 XLH
72 C30 Chevy truck
Old 11-09-2017, 05:48 PM   #18
CookieMonster
CookieMonster's Avatar
Hey, that ‘blowhard’ gave you two correct answers before everyone else repeated them, and put some fucking time into helping you. Plus he’s old enough to have earned the right to tease us young ‘uns.
I personally offer a no-hassle paint / parts ageing service: drop it off at my place any time you like and I’ll have it back to you old as new in 25yrs - good rates too.
Old 11-09-2017, 06:32 PM   #19
bobscogin
It'll wrinkle as the lacquer solvent attacks the enamel, but I've seen that happen and it doesn't look a lot like an old crazed, checked finish. Maybe it would work for him with some experimentation, however. You never know what works with off the wall stuff like this.
Bob
Old 11-09-2017, 07:08 PM   #20
Ratso
Ratso's Avatar
That was teasing? You could have fooled me.
