trio of trumps - Page 9 - The Jockey Journal Board
Old 04-21-2016, 11:53 AM   #161
richbob
richbob's Avatar
Default Re: trio of trumps
Good stuff
i would be interested to see plunger conversion
And details on layshaft.
Old 04-22-2016, 12:16 AM   #162
Dan Boy
Dan Boy's Avatar
Love the tight turns on that frame you made up. Was wondering what tube bender you use for that.
Dan.
Blown Triple Build
Old 04-22-2016, 08:48 AM   #163
image1's Avatar
i'll do my best to document the plunger conversion.
layshaft details to come. Long story short, i've got the early layshaft (non circlip) and will be changing to the later (t140 w/circlip). Also have a couple gear bushes to replace. I had bent the mainshaft, and never bothered to really check out the layshaft (which now i'm thinking was probably bent at the same time. Need to get a dial indicator on it and confirm.)
JD Squared Model 32. I don't remember what centerline radius i used though...
August 4-7, 2016!!!!!!!!!
http://r4yl.blogspot.com/
Old 04-27-2016, 09:38 AM   #164
image1's Avatar
cases split, sludge trap pulled. 15-20% full, looks like this will be a 20K regular service.
