1966 Bsa 650 on a budget - Page 8 - The Jockey Journal Board
Old 02-21-2020, 09:15 AM   #141
MikeJustice55
MikeJustice55's Avatar
Default
Originally Posted by Ratso View Post
What was your reasoning in running a single carb? Anything beyond "simple to tune"?
Sorry if you've explained this already. I'm too slothful to root around in this thread's early pages right now.
Manifold is a thing of beauty.
I appreciate that, it took me 3 times of cutting it apart and modifying it to make it fit properly. I prefer single carb for many reasons though. Easy to tune, only 1 throttle cable looks clean, i have a brass air cleaner ive wanted to put on a moyorcycle for about 15 years and decided it IS going on this build, and i like the carb not hanging out the sides.
MikeJustice55 is offline   Reply With Quote
Old 02-21-2020, 09:37 AM   #142
MikeJustice55
Default
So im not the best on the mill at work but im learning. Check out this clutch lever assembly I made. Part of it was my first bar riser i cut out but botched my measurements and had to recut them so i figured it would work well here. This is the first part ive made in a while that didnt feel easy for me. So its safe to say im proud of it.
ID:	256250   Click image for larger version
ID:	256252   Click image for larger version
ID:	256258   Click image for larger version
ID:	256260   Click image for larger version
ID:	256264   Click image for larger version
Old 02-21-2020, 03:51 PM   #143
Ratso
Ratso's Avatar
Default Re: 1966 Bsa 650 on a budget
WHOA!
I'm in danger of overcomplimenting your work, which would make you neurotic. "Whoa" was not a compliment, just an outburst.
Old 02-21-2020, 04:33 PM   #144
MikeJustice55
Default
WHOA!
Hahahaha no, i get it. I am super happy with how this turned out. Its very rewarding to see a tarnished "scrap" piece of brass turn into something so damn pretty. Bad news is... that was the last decent sized peice of 1 1/4" brass i had.
Old 02-21-2020, 05:34 PM   #145
Thebigguy0811
Default
DAMN!!!! I may as well use stone tools. You can be proud of that.
"It does not take a majority to prevail. What it takes is an irate, tireless minority, keen on setting brushfires of freedom in the minds of men."-John Adams
Thebigguy0811 is offline   Reply With Quote
Old 02-27-2020, 05:22 PM   #146
MikeJustice55
Default
So, making a throttle assembly was harder than expected and i came very close to ordering one. But since i finished it, im glad i made it. It works very smoothly. The part that the throttle cable slides into was made out of a second peice of scrap cut with a band saw drilled and bolted to the unit i made with a small groove to hold it in line. The bolt head acts as a stop and a second bolt was put in as the other throttle stop. This was the first time i have ever cut a groove inside a part with the lathe and im actually surprised I finished it within .005 of my drawing. I used a plastic throttle unit and cable that i got at a swap meet a while back for $4.00. Got the bars off Amazon for $18.99. $1.75 for hardware and brass was all freebies from leftovers from jobs. So this whole set up costs me less than $26.00. The brass got a rattle can coat of urethane clearcoat to stop oxidation and corrosion.
ID:	256348   Click image for larger version
ID:	256350   Click image for larger version
ID:	256354   Click image for larger version
ID:	256356   Click image for larger version
ID:	256360   Click image for larger version
ID:	256362   Click image for larger version
Old 02-28-2020, 05:53 AM   #147
Goldy
Goldy's Avatar
Some fine looking work there! Like I always say, you can buy lot'sa stuff, but you can't buy bragging rights!
This too shall pass.
Old 03-08-2020, 08:18 PM   #148
MikeJustice55
Default
This is the first time ive ever made custom pipes. I will be tigging them up. Smoothing out the welds a bit, then a coat of high temp black folled by exhaust wrap. I need to make a mounting bracket off of the frame as well where the pipes come together. Theae should look cool when theyre done tho.
ID:	256450   Click image for larger version
ID:	256452   Click image for larger version
Old 03-09-2020, 06:06 AM   #149
Goldy
Goldy's Avatar
Wow, that's a whole lot of fiddly-diddly work, but I'm sure the results will be awesome!
Old 03-09-2020, 08:35 PM   #150
MikeJustice55
Default
Tigged the pipes up. Spent about 3 hours smoothing them out, and pressure testing them for leaky welds. They are now air tight and ready for paint then exhaust wrap. Im going to put some baffles in as well because i dont like super loud.
Old 03-15-2020, 07:26 PM   #151
MikeJustice55
Default
Gave the pipes a high heat black paint job and wrapped with white exhaust wrap. Just need to make a mounting bracket and a couple heat shields and they will be all done.
ID:	256476   Click image for larger version
Old 03-15-2020, 10:40 PM   #152
Thunderbird
these skills are kinda making mine feel distinctly
https://www.google.co.uk/url?sa=i&ur...AAAAAdAAAAABAI
Old 03-17-2020, 02:07 PM   #153
MikeJustice55
Default
Hahaha im sure theyre not that bad. That made me Lol for real tho. 😂 just take you're time, anything can be done if you refuse to give up. Some things will take me multiple attempts and restarts. I am very greatful to have the tools i do have at my disposal but i have made things with just a torch and a grinder that would surprise people. Heres the exhaust heat shields i made out of an old Corvette sidepipe muffler i got for free a while ago.
ID:	256480   Click image for larger version
ID:	256482   Click image for larger version
Old 03-17-2020, 05:24 PM   #154
Ratso
Ratso's Avatar
Those are supercool. But don't they need about 150,000 speed holes to look finished?
Kidding. Speed holes would dink up their, uh, muted refinement and look cheap.
Old 03-17-2020, 06:16 PM   #155
MikeJustice55
Default
Haha i need speed holes in my frame and gas tank too
Old 04-07-2020, 06:54 PM   #156
MikeJustice55
Default
Made a master cylinder bracket and linkage to mount up for my harley disc brake rear. I ground down my old brake pedal surface and used tig braze silicon bronze over the surface about 3/16" thick and waffled it like the original but when i paint everything black the brass should pop. (Brake pedal was worn almost flat anyway) Also made an exhaust bracket to mount the pipes to the frame by cutting out a simple bracket and drilled and tapped for a 3/8 stud. Ill tig it solid when i tear down for finish welding and paint.
ID:	256830   Click image for larger version
ID:	256832   Click image for larger version
ID:	256840   Click image for larger version
Old 04-07-2020, 07:10 PM   #157
MikeJustice55
Default
I fabbed up a cool kicker pedal. It was harder than i thought it would be because i cant paint it to hide any imperfections. Also my old machinist friend at work showed me how to do a cool pattern on the lathe with a knurler to create a spiral instead of the normal cross hatching. Theres a lot of machine work into this with a delrin insert that was a press fit inside the stainless housing to keep it from rattling. And a machined oring groove to make it so it spins when necessary but wont flip or flop around while riding. It looks simple but it is NOT!.
ID:	256844   Click image for larger version
ID:	256846   Click image for larger version
ID:	256850   Click image for larger version
ID:	256852   Click image for larger version
Old 04-07-2020, 10:24 PM   #158
Ratso
Ratso's Avatar
It all looks slick as hell. That is a cool pattern you made with the knurler. Real tidy.
The four ears projecting radially from the end of the oil tank: what's their purpose going to be?
Old 04-08-2020, 05:49 AM   #159
Goldy
Goldy's Avatar
I really enjoy watching this workmanship. B.Z!
Old 04-08-2020, 07:34 AM   #160
MikeJustice55
Default
I unrolled and hammered out some brass material and gave it a brushed finish to do kind of a false brass cap on the sides of the tank. I will also put a sight guage on the same side as the fuel sight guage. Thats what the two plugged holes are for.
