Redesigning The 1956 Triumph - A Pre Unit Build by Alp - Page 12 - The Jockey Journal Board
Old 01-11-2012, 01:28 PM   #221
astek
astek's Avatar
Default Re: Redesigning The 1956 Triumph - A Pre Unit Build by Alp
Made the seat pan, i used 1/8" (3.04mm) thick cr steel.
www.alpracingdesign.com
Old 01-11-2012, 03:56 PM   #222
whittiger650
whittiger650's Avatar
Cool Re: Redesigning The 1956 Triumph - A Pre Unit Build by Alp
That's a really cool seat pan....looking forward to the finished product. What are you using to pad and cover it with ?
Jon
Old 01-11-2012, 05:11 PM   #223
astek
astek's Avatar
Thanks, will be using 1" closed cell foam for the padding and for the cover, the design we came up with will require combination of two materials: elk leather plus a contrasting softer material such as suede or something with a similar feel yet durable .
Old 01-12-2012, 11:14 AM   #224
Shrapnel84
Shrapnel84's Avatar
excellent fab work man this already is an incredible peice of work glad to see someone fab'n everything they can. great job ill be watching this thread closely
Shrapnel84 is offline   Reply With Quote
Old 01-20-2012, 03:22 AM   #225
astek
astek's Avatar
thanks Shrapnel84,
So in order to install the norton girder in to the triumph neck i had to machine a new stem. It will work with the tapered roller bearings since they are easily available.
Bottom bearing id is slightly larger than 1" and top id is 1"
Next i'm going to make the stem nut..
Old 01-24-2012, 01:21 AM   #226
astek
astek's Avatar
Default Front End Components
More front end parts that i made for the Norton girder.
The stem nut:
Steering damper knob, it is hand formed, so it's not even really symmetric, and i like the way it is..
Mini dog bones out of solid brass. 100% hand formed as well, like my frame slugs.. no cnc, no milling machine here!
There are not done yet, they will be send out for plating and polishing.
Old 01-24-2012, 03:16 AM   #227
knuckleworks
knuckleworks's Avatar
very nice but dumb as i am don't get the application yet
uıɐƃɐ ʎɐqǝ ɟɟo pɹɐoqʎǝʞ ɐ ʎnq ɹǝʌǝu ןן,ı
Lex Talionis
R I P Tippo 110426 my best friend for 13 years,you're missed
Old 01-24-2012, 01:27 PM   #228
akreone
Looking great Alp. Those brass dogbones are insanely rad.
akreone is offline   Reply With Quote
Old 01-24-2012, 02:01 PM   #229
Dan Boy
Dan Boy's Avatar
WOW, great as usual, I love that welding on the lathe. Nice work.
D.
Blown Triple Build
Old 01-24-2012, 03:02 PM   #230
bdavanza
bdavanza's Avatar
Amazing. I have the same lathe but I'm just learning to use it. inspiring, once again.
bdavanza is offline   Reply With Quote
Old 01-24-2012, 04:37 PM   #231
vorhese
vorhese's Avatar
This thread is the only reason I visit JJ
Old 01-24-2012, 06:34 PM   #232
firerat
nice tools man. awesome jig.nice work
firerat is offline   Reply With Quote
Old 01-25-2012, 09:59 AM   #233
LongHair
As always... only the finest of craftsmanship.
LongHair is offline   Reply With Quote
Old 01-30-2012, 12:13 AM   #234
astek
astek's Avatar
thanks guys,
hey knuckleworks, its nut just you, it took me days to figure out a clean set up, i will post pictures of the whole application when i'm done.
but i finished the spring bases/spacers for the seat.. the design is matching the handlebar connections..
Old 01-30-2012, 01:24 AM   #235
RaceFan
WOW, absolutely incredible.
I'm not sure if I want to go back into the garage again or just leave this stuff to the true craftsmen like you!
RaceFan is offline   Reply With Quote
Old 01-30-2012, 06:18 AM   #236
gaffe
Amazing work !
gaffe is offline   Reply With Quote
Old 01-30-2012, 07:52 AM   #237
Black Knight 1
Black Knight 1's Avatar
Danm ! This is art ...... Keep 'em coming !
La critique est aisee mais L'art est difficil.
(Criticizing is easy but art is difficult)
Black Knight 1 is offline   Reply With Quote
Old 01-30-2012, 10:09 AM   #238
supercrouton
supercrouton's Avatar
Now THAT is some creative fabrication! Great job.....Again!
Cheers, Dan.
Old 01-30-2012, 10:54 AM   #239
Rob Axel
Rob Axel's Avatar
Incredible craftsmanship...and attention to detail is something I am sure all of us could only dream of...
Great work!
"The heart is happiest
Old 01-31-2012, 10:55 AM   #240
bdavanza
bdavanza's Avatar
Did you grind a convex tool bit to achieve the curved groove or did you shape it by hand? Was the sleeve already on the frame or is it split? If that's brass, will it get brazed on to the lug? Elegant work.
Tags
alp, build, pre unit, rigid, triumph
