Build a 84" shovel. - The Jockey Journal Board
Old 07-26-2020, 01:25 PM   #1
longbow
Default Build a 84" shovel.
I have a S&S 74" and want to get 84" so my understanding is get 4 5/8 flywheels and bore the jugs 0.60 over and run 80" pistons is this correct?
Old 07-26-2020, 02:50 PM   #2
Default Re: Build a 84" shovel.
88.89 CI http://victorylibrary.com/tech/ci-ohv.htm
Old 07-26-2020, 05:05 PM   #3
longbow
Thanks Joe49. I saved that for future use.
Old 07-26-2020, 06:02 PM   #4
4 5/8'' arm is nice, but 4 3/4'' arm is even nicer.
Old 07-26-2020, 07:58 PM   #5
longbow
I was looking at a set of ultima wheels moneys tight. I all ready bought a set of there dual plug heads for 74 or 80 cylinders I farm and get a harvest bonus so thats what i use for this build. S&S block and cylinders. Kieth Black (9.5 to 1.
Old 07-27-2020, 06:36 PM   #6
longbow
So hows the 88" run? This is my first stroker build. Just looking for info such as cams ect. thanks craig
Old 07-27-2020, 06:53 PM   #7
They run OK. What you building. Daily or bar hopper or scary couple thousand mile maybe if your lucky TBO?
Old 07-31-2020, 08:46 PM   #8
longbow
A rigid bar hopper. longivity not so good i take it.
Old 07-31-2020, 09:36 PM   #9
Stay with a mild cam, and it will last close to stock, if you don't twist it past 6000 very often. I got to 70,000 with a 4 3/4'' by running a stock cam. Cam wouldn't let me rev over 5300, still would run off on the smaller twinkies.
Old 08-02-2020, 07:04 AM   #10
longbow
Im trying to keep the weight down it looks like i screwed up on wheels i put 16 on both ends then i read how 19 and 21 inch wheels weight less how much less?. And yes i want to eat a twinky theres a friend with a 88" duece that likes to make sure he lets you know his twink is faster. thanks craig
Old 08-14-2020, 05:24 PM   #11
longbow
Default cast pistons
I`m going thru the topend of a 74" shovel and was wondering whats the best cast pistons? the bottom end is good so i dont want to have to rebalance the flywheels. thanks craig
Old 08-15-2020, 10:50 AM   #12
Drag Specialties, Eastern, Jireh.
Old 08-15-2020, 11:03 PM   #13
longbow
Thanks Joe49
