Having a weird kicker issue with my ratchet top.
trans was fully rebuilt (by a reputable shop) before any of these issues.
i had to remove kicker cover for something or other this winter, and when i re-installed i *think* i indexed it wrong. Kicker would grab and swing down while running (bigger issue than just the return spring). Dissassembled everything, and gears were all pretty tore up. Bushing in ratchet gear no longer was seated in gear, but rather stuck to main shaft (not seized). I was able to get the bush off without heat or cutting, but it did NOT just slide off.
So, i decided that i would just buy the Baker gears and forego any future kicker problems.
Installed new Baker gears, and made sure everything was properly indexed and working correctly. Fired up the bike, took a couple rips around the block, few other starts as i did some tuning and got lights working.
Next day, i went to start the bike up, and after the 2 prime kicks, i had NOTHING. Not even trying to engage... So i pulled everything back apart to find some nice gold oil again. The bushing in the ratchet gear had walked outward toward cover enough that it would not allow the rachet gears to engage each other.
What would cause this??? My thinking at this point is that it has to be an issue with the shaft (brand new before this fiasco...) My other thought would be the key protruding just a tiny bit and grabbing the bushing (though i don't think this is the case, as i checked/played with this several times before i put the cover on to make sure it was seating/releasing correctly. There was no bind/tight spots with bushing on shaft.
Plan to call Baker this afternoon and pick their brains as well, just wondered if anyone here has had a similar issue?
