Rear Disc Brake Conversion Without Welding? - The Jockey Journal Board
Old 08-01-2011, 05:04 PM   #1
22100
Guest
Default Rear Disc Brake Conversion Without Welding?
My current frame is set up for a mechanical drum in the rear. I'm on a budget and have a disc setup I can swap from another bike. Any way I can change it over w/ out welding an anchor tab?
22100 is offline   Reply With Quote
Old 08-01-2011, 05:31 PM   #2
J_F_Byrd
Default Re: Rear Disc Brake Conversion Without Welding?
Sure can. A properly done tab incorporated into the caliper mount, which rests on the swingrarm is fine. Look at an HD Sporty or FXR caliper mount. If you're not a fabricator (or amateur engineer) and can't figure it out, post some photos for better advice.
J_F_Byrd is offline   Reply With Quote
Old 08-01-2011, 05:45 PM   #3
ElkCreek
ElkCreek's Avatar
I run a 3-peice clamp. Rock solid. Just remember to loosen it up when you adjust the chain.
Illegitimi Non Carborundum
( Dont Let The Bastards Grind Ya Down)
ElkCreek is offline   Reply With Quote
Old 08-02-2011, 03:37 AM   #4
sixball
sixball's Avatar
Why don't you want to weld it on ? Paint? Lack of welder? For piece of mind, I'd really consider welding the tab on, if you go with a caliper that requires a link style mounting point.
The 3 piece clamps do hold tight, but I don't know if I'd rely on that holding up if I had to lock up the rear in a close call situation.
Just my opinion.
Sixball
sixball is offline   Reply With Quote
Old 08-02-2011, 10:43 AM   #5
22100
Guest
Tried to add a picture to this post.
Old 08-02-2011, 11:31 AM   #6
sixball
sixball's Avatar
5 gallon bucket of ice water afew towels, a buddy to hold the towels on each side of where your going to weld the tab and alittle touch up paint, and your done.
You gota bare frame, and it's black, so any touch up work is simple.
Again, just my opinion of what I'd do for safety, and it'd be ALOT easier to do it now than before you get the bike put together
Sixball
Old 08-02-2011, 05:26 PM   #7
22100
Guest
Going back to your earlier question, I don't weld, so it would mean paying someone to do it for me. How much would a complete mechanical brake cost? I see a lot of components for sale, but never the complete package.
Old 08-02-2011, 09:06 PM   #8
JOCK E SHIFT
THATS a juice drum frame
JOCK E SHIFT is offline   Reply With Quote
Tags
brakes, disc, drum brakes, rigid
