Flyrite Choppers - Frames, Rollers, Parts - Page 9 - The Jockey Journal Board
Go Back   The Jockey Journal Board > The Jockey Journal Marketplace > Jock Shops
Old 03-21-2011, 07:02 PM   #161
sweetridewalsh
sweetridewalsh's Avatar
Default Re: Flyrite Choppers - Frames, Rollers, Parts
Flyrite Crew, can I please see a photo of the new Sportster "chopper" frame as a roller or more or less complete ? I am readdy to pull the trigger and order one but have searched high and low and come up with no photos ? Thank you for your time, your parts are dope.
Jasper
sweetridewalsh is offline   Reply With Quote
Old 03-22-2011, 11:38 AM   #162
FlyriteChoppers
FlyriteChoppers's Avatar
Jasper
Here is one that Benny is building @ http://www.boneshakerchoppers.co.uk/
FlyriteChoppers is offline   Reply With Quote
Old 03-25-2011, 11:04 AM   #163
FlyriteChoppers
FRC Grips - Black
Fits twist grip assemblies with a 1" & 1 1/8" size - 5" long
$5
Old 03-26-2011, 11:53 AM   #164
FlyriteChoppers
Paughco parts are priced to ship individually, please contact the shop to purchase multiples for a correct shipping total
Paughco Top Springs
Top springs for stock HD Big Twin and 45" Springers
(5 5/8" long x 1 1/2" diameter)
Paughco #162
$45.00/pair
** More than one available
Old 03-26-2011, 02:34 PM   #165
FlyriteChoppers
Paughco Bottom Springs
Bottom springs for Paughco and HD Springers
(6 1/4" long x 1 7/8" diameter)
Paughco #163
$55.00/pair
Old 03-26-2011, 02:35 PM   #166
FlyriteChoppers
Paughco Bottom Inner Springs
Bottom inner springs for narrow and wide Springers
(6 1/2" long x 1 1/8" diameter)
Paughco #163C2
$35.00/pair
Old 03-26-2011, 02:36 PM   #167
FlyriteChoppers
Paughco Top Inner Springs
Top inner springs for narrow and wide Springers
(4" long x 3/4 " diameter)
Paughco #163C4
$35.00/pair
Old 03-26-2011, 06:05 PM   #168
FlyriteChoppers
Spring Rod top nuts
For early HD Springers
Paughco #165/OEM #45647-36
$14.00
Old 03-26-2011, 06:05 PM   #169
FlyriteChoppers
Acorn nuts
For all Paughco Springers and early HD Springers with 1/2"-20 thread pitch
Paughco #166/OEM #45648-36
$14.00
Old 03-27-2011, 07:17 PM   #170
FlyriteChoppers
Rockers
Drop forged & chrome plated, comes with bushing pre-installed
With 3/4" axle holes for use with 3/4" axles and axle kits
Paughco #168-1
$126.00
*Special* $99
Old 04-01-2011, 11:55 AM   #171
FlyriteChoppers
FRC Grips - Metal Flake
Red
***all sold***
Old 04-01-2011, 12:55 PM   #172
FlyriteChoppers
FRC Grips - Red
$5
Old 04-02-2011, 10:42 PM   #173
FlyriteChoppers
FRC Risers for 1" bars- 2"
FRC's aluminum risers, featuring FRC's RiteTite™ clamping system are for 1" bars & bolt thru from the top.
Includes allen head bolts for the counter sunk top clamps.
Brushed aluminum can be run as they are or polished, anodized or finished as desired.
SOLD OUT.
Old 04-07-2011, 01:36 PM   #174
FlyriteChoppers
**SOLD**
Old 04-13-2011, 09:20 AM   #175
FlyriteChoppers
FRC Risers for 7/8" bars - 5"
FRC's aluminum risers, featuring FRC's RiteTite™ clamping system are for 7/8" bars & bolt thru from the top.
Available in brushed or black anodized.
$124/pair
Brushed
$144/pair
Black
Last ones ever.
Old 04-15-2011, 12:23 PM   #176
FlyriteChoppers
FRC Frame Neck
You asked for it & here it is...
Frame Neck for 1-inch neck stem
*Special*
$35
Old 04-15-2011, 09:48 PM   #177
FlyriteChoppers
FRC Seat Pan - raw
Consists of a heavy gauge steel pan, pre-drilled for upholstering. This is the same pan used on FRC bikes.
Dimensions: 9” wide x 12˝” long.
Hand fabricated in house at Flyrite Choppers.
*Special*
$40
Old 04-19-2011, 10:57 AM   #178
FlyriteChoppers
Custom Chrome Rear Wheel - 180
40 Spoke!!!!! Old stock, havent been made in 3 years.
CCI # 08810 - CHR.16X5 R/WHL.X-WIDE HUB
$299
Old 04-21-2011, 11:21 AM   #179
FlyriteChoppers
FRC Fuel Sight Gauge - red
Kit includes: 2 weld on bungs, 2 chrome 90° barb ends, 2 stainless steel hose clamps, and 1 6" piece 3/8" fuel line (red) Welding and drilling required.
$40
Old 04-22-2011, 11:19 AM   #180
FlyriteChoppers
Smile Re: Flyrite Choppers - Frames, Rollers, Parts
FRC Points cover
Cast points cover with ‘FRC’ for BigTwin
Mounting hardware included
$5
Tags
bobber, brakes, chopper, digger, frames, handlebars, parts, risers, spools, springer
HTML code is Off
