Flyrite Choppers - Frames, Rollers, Parts - Page 5 - The Jockey Journal Board
Go Back   The Jockey Journal Board > The Jockey Journal Marketplace > Jock Shops
Old 02-05-2010, 04:02 PM   #81
FlyriteChoppers
FlyriteChoppers's Avatar
Default Re: Flyrite Choppers - Frames, Rollers, Parts
FRC Narrow Apes are back in stock - $44.95-$49.95
Chrome plated 1" steel tubing -- 33" wide, 7" center, no recess, no knurling, available in 12" or 16" heights (12" shown here)
FlyriteChoppers is offline   Reply With Quote
Old 02-10-2010, 09:32 PM   #82
FlyriteChoppers
Bored? Check out the newly expanded archives section at FRC...
Old 02-17-2010, 05:49 PM   #83
FlyriteChoppers
The Bobber Frame - $875
For Big twin motors, pan head, shovel head, evo
  • Flyrite Choppers 'Bobber' rigid frame -33° rake, 2" stretch in down tubes - 130 mm rear - (includes MSO)
  • Frames are set up to accept big twin motors, pan head, shovel head, evo.
Old 02-19-2010, 04:15 PM   #84
FlyriteChoppers
FRC's Annual Tax Time Specials are here -- Savings on frames, rollers, parts & apparel at www.FlyriteChoppers.com
Old 02-26-2010, 11:04 AM   #85
FlyriteChoppers
Outlaws Ruin Frame - $975
  • Flyrite Choppers Outlaws Ruin rigid frame -33° rake, 2" stretch in down tubes - 180 mm rear - (includes MSO)
Old 03-03-2010, 05:48 PM   #86
FlyriteChoppers
FRC SpeedLine Front Brake Rotor - $125
11.5" rotor - 420 polished stainless
Old 03-03-2010, 08:02 PM   #87
TEACH
TEACH's Avatar
Thanks for the donation of the sporty frame to the chopper class..great quality frame you guys RULE!
www.Baasmetalcraft.com
Custom made garage built custom bike stuff
Vintage Bike Addiction..blog
http://vintagebikeaddiction.blogspot.com/
Kennedy High School Chopper Class
http://www.kennedychopperclass.com/
TEACH is offline   Reply With Quote
Old 03-08-2010, 02:40 PM   #88
Scorcher
Administrator
Scorcher's Avatar
Send a message via AIM to Scorcher Send a message via Yahoo to Scorcher
Looking forward to seeing the finished bike!!!
-Jason
Scorcher is offline   Reply With Quote
Old 03-11-2010, 05:59 PM   #89
FlyriteChoppers
Reach for the Sky Frame - $875
  • Flyrite Choppers Reach for the Sky rigid frame -30° rake, no stretch in down tubes - 130 mm rear - (includes MSO)
Old 03-24-2010, 01:16 PM   #90
FlyriteChoppers
High Noon Frame - $975
  • Flyrite Choppers High Noon rigid frame -30° rake, no stretch in down tubes - 180 mm rear - (includes MSO)
Old 03-30-2010, 10:58 PM   #91
FlyriteChoppers
Available for free download -- monthly calendar wallpapers
www.flyritechoppers.com
Old 04-07-2010, 05:53 PM   #92
FlyriteChoppers
FRC Aluminum Spool Hub - Rounded
FRC's narrow spool hub is reminiscent of vintage styles of old.
40 spoke, for 5/8" or ľ" axle.
Includes axle spacing sleeve.
$105.00
Old 04-15-2010, 04:11 PM   #93
FlyriteChoppers
FRC Triumph™ Hard Tail Bolt-on- $275
Old 04-21-2010, 04:09 PM   #94
FlyriteChoppers
*Now Available for 7/8" bars*
FRC Risers - 2" - $94
FRC's slender aluminum risers, featuring FRC's RiteTite™ clamping system are for 7/8" bars & bolt thru from the top.
Includes allen head bolts for the counter sunk top clamps.
Old 04-24-2010, 12:34 AM   #95
FlyriteChoppers
FRC Risers - 3" - $109
Old 05-04-2010, 07:30 PM   #96
FlyriteChoppers
*NEW* Click to add a free Flyrite persona to your Firefox browser
Old 05-19-2010, 11:19 AM   #97
FlyriteChoppers
Flyrite Choppers is looking for a part-time/Full time(3-4 days a week) machinist. Our current machinist works Thurs and Friday and works full time elsewhere.
Must be able to set up and operate a variety of manual/conventional machine tools to include Bridgeport style mills, lathes. Other equipment used will be 4th axis rotary, drill presses, hydraulic presses.
The two machines you would be using frequently is a Haas VF2 and an Okuma LB15.
Mastercam Xxx experience is mandatory.
Solidworks experience is mandatory.
Experience with Steel Stamping and Aluminum Casting will be a big plus.
Primary Responsibilities:
- Fabricate New parts in development for Flyrite Choppers
- Work to build new parts line for Flyrite Hotrods.
- Measure work carefully with precision of +/- .0005 consistently
- Perform preventative and predictive maintenance on all shop equipment
- Care for precision instruments by cleaning at the end of each work day and storing properly
- Perform some CNC setup and operation experience (Specifically to the HAAS control)
Ability To:
- Visualize parts or equipment that need to be made for rough sketches and/or oral instruction
- Read blueprints, shop drawings, sketches, models or other visual aids
- Maintain a clean and well organized work area
- Stay focused on the job at hand
- Arrive to work on time
- Communicate effectively with other shop personnel
If you have what it takes, PM us.
Thanks.
Old 05-25-2010, 03:14 PM   #98
FlyriteChoppers
FRC Risers - 5" - $124
Old 05-27-2010, 04:37 PM   #99
FlyriteChoppers
Still looking ...........
Flyrite Choppers
Ability To:
Thanks.
Old 06-04-2010, 04:09 PM   #100
FlyriteChoppers
The machinist position is now a FULL TIME Position, Monday - Friday 9:00 - 5:00.
-FRC
Tags
bobber, brakes, chopper, digger, frames, handlebars, parts, risers, spools, springer
HTML code is Off
