#61 |
FRC Seat Bungs- $15
Seat bungs as used on FRC frames ![]() |
Sponsored Links | |||
#62 |
![]() ![]() FRC Logo T-Shirt - black - $15 T-Shirts are short sleeve Gildan - 100% Preshrunk Cotton |
#63 |
Another Smokin Gun based build from Boneshakers, UK...
#64 |
Back in Stock! FRC Oil Filter Mount - Finned - $105
![]() Cast aluminum oil filter mount is available for left or right side application. Fits 1" Tubing. Takes Stock HD Filter, 1/8 NPT fittings Last edited by FlyriteChoppers; 03-24-2010 at 01:05 PM. |
#65 |
FRC Grips - Black - $15
Fits twist grip assemblies with a 1" & 1 1/8" size - 5" long ![]() |
#66 |
#67 |
FRC Grips - White - $15
#68 |
FRC Grips - Metal FlakeSilver - $15
#69 |
NEW from FRC -- Stainless Steel Bearing Cup Sets
![]() 'Hive' Style Shown Last edited by FlyriteChoppers; 01-08-2010 at 03:12 PM. |
#70 |
![]() ![]() FRC Stainless Steel Bearing Cup Set - Inverted - $118/pair, $148/kit FRC's custom designed bearing cup set fits FRC frames & most others with 1 neck. ** Available as 1" cups only or as full kit (includes 1" Cups, Bearings, ,Races & Dust Shields). Replaces OEM 48315-60/48300-60/48311-60/43865-48A & 48361-80 |
#71 |
![]() ![]() FRC Stainless Steel Bearing Cup Set - Hive - $118/pair, $148/kit FRC's custom designed bearing cup set fits FRC frames & most others with 1 neck. ** Available as 1" cups only or as full kit (includes 1" Cups, Bearings, ,Races & Dust Shields). Replaces OEM 48315-60/48300-60/48311-60/43865-48A & 48361-80 |
#72 |
![]() ![]() FRC Stainless Steel Bearing Cup Set - Sprocket - $118/pair, $148/kit FRC's custom designed bearing cup set fits FRC frames & most others with 1 neck. ** Available as 1" cups only or as full kit (includes 1" Cups, Bearings, ,Races & Dust Shields). Replaces OEM 48315-60/48300-60/48311-60/43865-48A & 48361-80 |
#73 |
![]() ![]() FRC Stainless Steel Bearing Cup Set - Saucer- $118/pair, $148/kit FRC's custom designed bearing cup set fits FRC frames & most others with 1 neck. ** Available as 1" cups only or as full kit (includes 1" Cups, Bearings, ,Races & Dust Shields). Replaces OEM 48315-60/48300-60/48311-60/43865-48A & 48361-80 |
#74 |
![]() ![]() FRC Stainless Steel Bearing Cup Set - Rounded- $118/pair, $148/kit FRC's custom designed bearing cup set fits FRC frames & most others with 1 neck. ** Available as 1" cups only or as full kit (includes 1" Cups, Bearings, ,Races & Dust Shields). Replaces OEM 48315-60/48300-60/48311-60/43865-48A & 48361-80 |
#75 |
![]() ![]() FRC Stainless Steel Bearing Cup Set - Cog - $118/pair, $148/kit FRC's custom designed bearing cup set fits FRC frames & most others with 1 neck. ** Available as 1" cups only or as full kit (includes 1" Cups, Bearings, ,Races & Dust Shields). Replaces OEM 48315-60/48300-60/48311-60/43865-48A & 48361-80 |
#76 |
![]() ![]() FRC Primary Front Brake Kit for glide - BRUSHED finish - $535 Includes: 4 piston caliper for single disc front end, 11.5" rotor, & rotor mounting hardware for glide front end with 3/4" axle |
#77 |
Customer build from the FRC Loner frame
#78 |
FRC Grips - Metal Flake Red - $15
#79 |
FRC Risers - 3"
FRC's aluminum risers, featuring FRC's RiteTite™ clamping system are for 1" bars & bolt thru from the top. Includes allen head bolts for the counter sunk top clamps. These can be run as they are or polished, anodized or finished as desired. $109/pair ![]() Last edited by FlyriteChoppers; 04-23-2010 at 12:40 PM. |
#80 |
February FRC Calendar Wallpaper now available...
download here: http://www.flyritechoppers.com/Pg/FRCWallpaper.html ![]() |
Tags |
bobber, brakes, chopper, digger, frames, handlebars, parts, risers, spools, springer |
Display Modes | |
