fitting an 883 evo motor in a 1973 sporty frame, problems - The Jockey Journal Board
Old 09-08-2011, 04:24 PM   #1
thomsengood
Default fitting an 883 evo motor in a 1973 sporty frame, problems
Hey there, i have just fittet a 883 evo sporty motor in my 1973 xlch frame, and now i cant get the rear fork to fit, theres not room betwen the motor and the frame, and it sucks.... does any of you people have iders to what i do to solw the problem? i must tell you that here i Denmark where i live modifications of the frame is by law, not an option......
thomsengood is offline   Reply With Quote
Old 09-08-2011, 04:29 PM   #2
Jtw79
Jtw79's Avatar
Default Re: fitting an 883 evo motor in a 1973 sporty frame, problems
By rear fork do you mean the swingarm? Need a picture to see what the clearances are. Oh and do you mean you can modify the frame or can not because of laws? Would like to help.
Jtw79 is offline   Reply With Quote
Old 09-08-2011, 05:09 PM   #3
panhead_pete
If you can mate post some pics. If you arent sure how its quite easy. Just join photobucket.com and once you have the pic uploaded copg the [img] line and paste it in a thread. If you already know this please disregard.
Thanks
Pete
Old 09-08-2011, 05:16 PM   #4
cyclonite
Talking Re: fitting an 883 evo motor in a 1973 sporty frame, problems
Hi There Thomsengood
I have not done this but here is a Japanese Blog by a guy that has done it, use the Google tool bar to translate it and you should get a lot of good stuff from it
http://inuchopper.blogspot.com/
Sorry I can't help more, I am keeping me XLCH 1000 and me 04 883 well away from each other ;-)
Brian
http://xlch1000.blogspot.com/
cyclonite is offline   Reply With Quote
Old 09-08-2011, 05:19 PM   #5
66xlch
It's going to be the spot just left of the rear motor mount. On Ironheads it has a notch to clear the pivot bolt/nut. You're prolly gonna need to cut/weld the offending portion of the primary case to make room, assuming you have the space behind the clutch, of course. Pics would be nice, but I think that's where the problem lies.
66xlch is offline   Reply With Quote
Old 09-08-2011, 07:14 PM   #6
bobscogin
Brian
Looks like he mated an Ironhead rear section to an Evo front section. There's a couple of photos of the process.
Bob
Old 09-09-2011, 10:25 AM   #7
thomsengood
Thanks for the replys, i dont seem to be able to post pictures( have tryed) your right its the space betwen the backside of the clutchshield and swinger that makes the problem, its that damn stator wire output. but welding is not an option for us here in Denmark, the authoreties wil confiscate my bike and fine me right into hell if i do......
Old 09-09-2011, 11:10 AM   #8
66xlch
Thank god the government is protecting us from all those dangerous welded bikes. maybe a freeze plug and then a new hole for the wires?
Old 09-09-2011, 01:17 PM   #9
bobscogin
Then it must be a 4 speed Evo with the alternator in the clutch?
Bob
Old 09-09-2011, 08:51 PM   #10
that_stupid_kydd
that_stupid_kydd's Avatar
ya, some laws don't make sense. where i am the handle bars can't be more then 15 inches over your seat and to pass a safety i have to have a front break and both fenders
i own a bike, not just a shirt
that_stupid_kydd is offline   Reply With Quote
Old 09-10-2011, 05:19 AM   #11
thomsengood
i have been looking at the inside of the clutchhousing and theres no room for moving the wires, maybe a swingarm from a 1979 sportster is a posibility, but i cant find the specks anywhere?
Old 09-10-2011, 05:32 AM   #12
Neo Dutch
Neo Dutch's Avatar
Post pics using the attachment method.
Chuck that Knuck, Flat is where it's At.
Neo Dutch is offline   Reply With Quote
Old 09-10-2011, 05:37 AM   #13
panhead_pete
https://www.jockeyjournal.com/forum/s...sting+pictures
Thanks
Pete
Old 09-10-2011, 09:13 AM   #14
bobscogin
The '79-'81 swing arm is the same as previous models with regard to the pivot end that attaches it to the frame. Of course, it's a rectangular tube cross section and for use with disk brakes but that doesn't change anything for your purposes.
Bob
Old 09-10-2011, 12:51 PM   #15
66xlch
Yeah, I doubt the '79-up S/A will help. You're gonna need to reroute those wires, one way or another.
Old 09-11-2011, 08:49 AM   #16
thomsengood
Is there anyone who knows if a rear swinger from a 2005 sporty will fit on my 1973 frame, that migt do the trick with the problem with space betwen frame and clutchhousing, it seems to bee a bit narrower than the original????
Old 09-11-2011, 11:04 AM   #17
bobscogin
Not likely. The 2005 swing arm mounts to the engine/transmission case. The odds that it would interchange with a '73 are slim to none.
Bob
