Triumph Engine Stand - The Jockey Journal Board
Old 12-19-2013, 06:35 PM   #1
BulletT120R
Default Triumph Engine Stand
Anyone have any measurements or a engineers drawing with specs for a 650/750 engine stand.
At the workshop and no Engine to use to get measurements.
Cheers
BulletT120R is offline   Reply With Quote
Old 12-19-2013, 06:38 PM   #2
BulletT120R
Default Re: Triumph Engine Stand
Sorry like this
Old 12-19-2013, 07:35 PM   #3
Loffer
Loffer's Avatar
I woukd say those dimensions are as easy as typing this thread . Make 4 tabs,,.bolt them on ,weld 2 flat pieces on to tabs and weld to a 90 while attatched to motor. Cut off excess sq . Stock. Couple pieces of angle for the base.
Loffer is offline   Reply With Quote
Old 12-20-2013, 06:27 AM   #4
Yup, that was pretty much how I made mine..... It may not look as nice, but it works. If you want I will measure it later today and make a "drawing" with the basic layout....
OK, here ya go...yeah I know it looks like shit....but it served its purpose...
Old 12-22-2013, 10:02 AM   #5
BulletT120R
Appreciate the help Rob your a champ saved me a lot of time here!
Old 12-23-2013, 03:29 PM   #6
Tre900
I used a bolt and drilled some holes through a couple pieces of scrap for the top holes.
I'm a cheap bastard that can't weld very well but it works. Its also made out of a recycled weight lifting bench. Just put something together and go with your gut.
Searching on this site got a document with exact dimensions too. Good luck
Tre900
_
(_)=='(_)
Tre900 is offline   Reply With Quote
