Harley wr rear hub - The Jockey Journal Board
Old 03-21-2020, 04:09 PM   #1
scout
Default Harley wr rear hub
Can anyone show me a 48 wr rear wheel hub ?? All the ones I keep coming across are kr advertised as wr and I know there is a difference in the bearings. But not sure what else
thanks in advance
[SIGPIC][/SIGPIC]
scout is offline   Reply With Quote
Old 03-22-2020, 05:37 AM   #2
thefrenchowl
thefrenchowl's Avatar
Default Re: Harley wr rear hub
Hi,Scout,
Yes, part numbers are different, but the last WRs like yours ran the same metric ball bearings as early KRs, so they can't be much differences in the hub itself, apart from spacers and axle.
Since the wheel sprockets are the same, WR or KR xx xxx-47R or -48R, one can assume adapting a KR rear hub to a WR won't be an insurmontable challenge.
Patrick
Anyone that can play drums with underwear on their head while wearing a monocle is alright in my book...
https://web.archive.org/web/20071011....com/index.htm
thefrenchowl is offline   Reply With Quote
Old 03-22-2020, 08:33 AM   #3
Sporticus
Sporticus's Avatar
Originally Posted by thefrenchowl View Post
Hi,Scout,
Patrick
Patrick - this doesn't address the OP's question, but maybe you know. I'm very curious to know why Harley would use metric ball bearings over 70 years ago. I'm not old enough to remember first hand, but I didn't realize the metric system had even made inroads into the US that far back. Any ideas?
Sporticus is offline   Reply With Quote
Old 03-22-2020, 11:16 AM   #4
Harley out sourcing hub is Triumph I believe.
Old 03-22-2020, 01:02 PM   #5
scout
Does anyone have any photos they can post
[SIGPIC][/SIGPIC]
Old 03-22-2020, 03:08 PM   #6
No pics in Palmer's.
Old 03-22-2020, 04:07 PM   #7
thefrenchowl
Don't really know about the WR, but the KR is deffo full of metric bearings from the start... Same for the K/KH wheels, metric as well, 17 x 40 x 12 if I remember right, DIN ref 6203... 2 x on front wheel, 3 x on the back.
KR engine ball bearings are 25 x 52 x 15, DIN ref 6205, on the crank mainshaft, 25 x 47 x 12, DIN ref 6005, on the crank timing side, HD Race Dept told you to mod the sprocket crowded rollers and machine the case/shaft to fit the 25 x 52 x 15, KR cams spin on 9 x 24 x 7, DIN ref 609...
Extract from KR parts book(… I like the prices!!!...):
Old 03-23-2020, 03:59 AM   #8
I thought triumph was imperial up until early 70's
