oil tank pressurized, way pressurized! help? - The Jockey Journal Board
Old 07-13-2010, 09:35 AM   #1
loser
loser's Avatar
Default oil tank pressurized, way pressurized! help?
I have a evo sporty and the oil tank has so much pressure it pops the cap u cant even ride the fuck'n thing. just got it runni'n. tank to small? breather gear? oil pump? Thanks.
loser is offline   Reply With Quote
Old 07-13-2010, 11:16 AM   #2
WhiteFox
Default Re: oil tank pressurized, way pressurized! help?
I believe there is a vent line that runs from the bottom up to the top of the inside of the tank (above the oil level). Be sure that this line is not pinched or it could contribute to your problem. If I remember correctly, this is the line that goes to the rear of the cam cover with a 90* elbow.
Edit: Yep, I was correct I just looked at my motor.
WhiteFox is offline   Reply With Quote
Old 07-13-2010, 11:25 AM   #3
Unkl Ian
Unkl Ian's Avatar
Location: Just past the corner of Hell and The Twilight Zone.
How much oil is in the tank ?
How close to the top ?
FlyingEyeballs.net
Unkl Ian is offline   Reply With Quote
Old 07-13-2010, 02:21 PM   #4
JPP
JPP's Avatar
I had my crankshaft "breather" line stucked and it popped out the cap from the oil tank.
JPP is offline   Reply With Quote
Old 07-13-2010, 03:06 PM   #5
Unkl Ian
Unkl Ian's Avatar
New cap ?
The tank needs to be vented somehow.
FlyingEyeballs.net
Old 07-14-2010, 09:25 AM   #6
LightninMike
LightninMike's Avatar
no breather gear on an evo sporty..... so heres where ya need to look:
you have pressure, too much pressure....this means the crankcase is NOT breathing....
is it the head breathers or the case breather???....
did you change anything?...
did you add anything?....
did you take anything away?....
it might sound like those last three questions are all the same, but they aren't.... something is different from stock, and that's where the problem is
Insert witticism here
LightninMike is offline   Reply With Quote
Old 07-14-2010, 10:08 AM   #7
kickstarts
kickstarts's Avatar
Originally Posted by lightninmike View Post
no breather gear on an evo sporty..... So heres where ya need to look:
You have pressure, too much pressure....this means the crankcase is not breathing....
Is it the head breathers or the case breather???....
Did you change anything?...
Did you add anything?....
Did you take anything away?....
It might sound like those last three questions are all the same, but they aren't.... Something is different from stock, and that's where the problem is
x2.
kickstarts is offline   Reply With Quote
Old 07-14-2010, 03:19 PM   #8
Jeffro
Jeffro's Avatar
To much oil in tank. Manual says around 3qts, run 2 1/2. Wife did that when she decided to change the oil.
Jeffro is offline   Reply With Quote
Old 07-14-2010, 03:55 PM   #9
Dave63
Dave63's Avatar
Last one I saw like this was a blocked return hose with a piece of papertowel in it....
Dave63 is offline   Reply With Quote
