Alternatives to pressing flywheels out of the case - The Jockey Journal Board
Old 04-13-2013, 05:13 PM   #1
JMH78FX
Default Alternatives to pressing flywheels out of the case
I have my 78 shovel torn down and looking for some help. Are there any SAFE ways of removing the flywheels from the case half without pressing them out? I don't have an arbor press handy. Is there another method of doing it that won't screw up the case or the crank..... As always, thanks for the help
JMH78FX is offline   Reply With Quote
Old 04-13-2013, 05:25 PM   #2
slim55g
slim55g's Avatar
Default Re: Alternatives to pressing flywheels out of the case
Damn it Jessie, you got an answer for everything don't ya !!!
slim55g is offline   Reply With Quote
Old 04-13-2013, 05:32 PM   #3
HD48FL
Super Moderator
And he's quick too!
Either get the tool or find a machine shop in your area that has a press, should be relatively easy to find one?
Old 04-13-2013, 05:39 PM   #4
Rubone
The factory tools are all screw press tools. Easy to make from old junk. For years I used one made out of an old brake disc with a center plate added with a 3/4 inch nut welded to it and a 3/4 inch bolt for the press. Holes drilled to match case holes (primary cover). Slight warming always helps as well.
Rubone is offline   Reply With Quote
Old 04-13-2013, 05:54 PM   #5
JAWS
JAWS's Avatar
Don't limit your self to factory seats.
The automotive industry has lots of seats that could be made to work. I know you have a mill and lathe...Press fit with a thou or so interference.
Just saying, way back if the stock seat didn't work from a chevy, maybe that ford one would with some creative trimming, hell even that one from a caddy.
Old 04-13-2013, 07:08 PM   #6
JMH78FX
Thanks Dragstew and Rubone. Got it. I looked up the Jim's tool...its $180.... Like you both said... easy enough to make. Thanks folks. Damn I like having the JJ community around to help.
Old 04-14-2013, 09:01 AM   #7
joe49
joe49's Avatar
I would not go over .005 for press with those castings not much meat there.
Old 04-17-2013, 05:00 AM   #8
concrete guy
Damn! You MUST be bored Joe! LMA0!
concrete guy is offline   Reply With Quote
Old 04-17-2013, 08:43 PM   #9
joe49
joe49's Avatar
just a lil'
