Another question on voltage regulator location - The Jockey Journal Board
Old 07-20-2013, 05:59 PM   #1
JMH78FX
Default Another question on voltage regulator location
We're fab'ing a custom exhaust for my trike project that runs front the front exhaust pipe down between the front legs and then runs it aft under the primary. It takes out the traditional location for the voltage regulator.
The regulator needs air flow, and I have lots of places that can give it that. The question I have is are there any issues with long leads (wires) that will be needed to locate it somewhere else (Impedance problems etc.) or am I ok as long as I get it in the wind.
JMH78FX is offline   Reply With Quote
Old 07-20-2013, 06:30 PM   #2
lht
Default Re: Another question on voltage regulator location
i'd say stock location is as far away from battery as your gonna get any where else will be shorter wires no problem
lht is offline   Reply With Quote
Old 07-20-2013, 06:56 PM   #3
wire length will not matter, just use same gauge wire.
Old 07-20-2013, 08:20 PM   #4
JMH78FX
Thanks I appreciate the input.
