Build a 84" shovel. - The Jockey Journal Board
Old 07-26-2020, 02:25 PM   #1
longbow
Default Build a 84" shovel.
I have a S&S 74" and want to get 84" so my understanding is get 4 5/8 flywheels and bore the jugs 0.60 over and run 80" pistons is this correct?
longbow is offline   Reply With Quote
Old 07-26-2020, 03:50 PM   #2
joe49
joe49's Avatar
Default Re: Build a 84" shovel.
88.89 CI http://victorylibrary.com/tech/ci-ohv.htm
OLD MOTORCYCLE ENTHUSIAST
Old 07-26-2020, 06:05 PM   #3
longbow
Thanks Joe49. I saved that for future use.
Old 07-26-2020, 07:02 PM   #4
joe49
joe49's Avatar
4 5/8'' arm is nice, but 4 3/4'' arm is even nicer.
Old 07-26-2020, 08:58 PM   #5
longbow
I was looking at a set of ultima wheels moneys tight. I all ready bought a set of there dual plug heads for 74 or 80 cylinders I farm and get a harvest bonus so thats what i use for this build. S&S block and cylinders. Kieth Black (9.5 to 1.
Old 07-27-2020, 07:36 PM   #6
longbow
So hows the 88" run? This is my first stroker build. Just looking for info such as cams ect. thanks craig
Old 07-27-2020, 07:53 PM   #7
joe49
joe49's Avatar
They run OK. What you building. Daily or bar hopper or scary couple thousand mile maybe if your lucky TBO?
Old 07-31-2020, 09:46 PM   #8
longbow
A rigid bar hopper. longivity not so good i take it.
Old 07-31-2020, 10:36 PM   #9
joe49
joe49's Avatar
Stay with a mild cam, and it will last close to stock, if you don't twist it past 6000 very often. I got to 70,000 with a 4 3/4'' by running a stock cam. Cam wouldn't let me rev over 5300, still would run off on the smaller twinkies.
Old 08-02-2020, 08:04 AM   #10
longbow
Im trying to keep the weight down it looks like i screwed up on wheels i put 16 on both ends then i read how 19 and 21 inch wheels weight less how much less?. And yes i want to eat a twinky theres a friend with a 88" duece that likes to make sure he lets you know his twink is faster. thanks craig
Old 08-14-2020, 06:24 PM   #11
longbow
Default cast pistons
I`m going thru the topend of a 74" shovel and was wondering whats the best cast pistons? the bottom end is good so i dont want to have to rebalance the flywheels. thanks craig
Old 08-15-2020, 11:50 AM   #12
joe49
joe49's Avatar
Drag Specialties, Eastern, Jireh.
Old 08-16-2020, 12:03 AM   #13
longbow
Thanks Joe49
Old 10-22-2020, 04:08 PM   #14
longbow
My old post follow up. I decided on a set of KB 9.5.1 80" for pistons but still waiting on a set of flywheels. I was hoping for a set of ultimas but cant get them so might go with S&S just alot of money.
Old 10-22-2020, 05:01 PM   #15
joe49
joe49's Avatar
Pistons for a stock 80 are not going to work with out modifications with 4 5/8'' stroke wheels. Or you keeping it 80''?
Old 10-22-2020, 05:47 PM   #16
longbow
I will keep this one 80"
Old 10-22-2020, 11:11 PM   #17
tomsoftail
tomsoftail's Avatar
I thought that you could only go with 4.25" wheels without the taller jugs.?. I've been wrong before.
Old 10-23-2020, 02:54 PM   #18
longbow
Ya im going to just buld a 80 for my 75 flh so need new 80 wheels
Old 10-23-2020, 03:11 PM   #19
joe49
joe49's Avatar
Nope. Stock bore S&S pistons run in stock cylinders @ 5.330''.
Old 10-23-2020, 03:19 PM   #20
joe49
joe49's Avatar
If you have a complete 74 inch the standard 80 inch pistons will work they are .060 o/s of a 74. That would be a real waste of stock 74 cylinders that may likely clean up at a smaller oversize. Back on 74 vs 80 you won't notice much difference between them even as you stroke them bigger with the same accompanying mods to both.
