SU Eliminater2 carb - The Jockey Journal Board
Old 11-07-2019, 03:10 AM   #1
john the hat
Default SU Eliminater2 carb
Got an 88" stroker S&S motor running Andrews C grind cam and cannot get the carb to get past firing,wont carry on running. Been fitted with a rebuild kit,pumper puts fuel in ,fires on that initial fuel then dies .Any help would be greatly apreciated as no-one in australia seems to be able to help me ,cheers all
john the hat is offline   Reply With Quote
Old 11-08-2019, 08:30 PM   #2
hammerweight
hammerweight's Avatar
Default Re: SU Eliminater2 carb
http://www.clubchopper.com/forums/sh...rb-assist.html
This might help.....
www.marshallmetalshaping.com
hammerweight is offline   Reply With Quote
Old 11-09-2019, 04:07 AM   #3
I read that and i just had exactly the opposite on a CV carb
hard to start bike but eventually did and no fuel from pump accelerator nozzle. Reason was gummed up ball bearing under brass nozzle.(after checking diaphragm first)
Pulled out cleaned and she's a squirter.
Old 11-09-2019, 08:00 AM   #4
I believe that's called the Grose jet, and yeah, that is a common gumming area. I would spray that out with some 2+2 or the like for starts.
Also, some fuckface wrote this: https://www.jockeyjournal.com/forum/...d.php?t=211769
Maybe that might help you some.
govmule84 is online now   Reply With Quote
Old 11-10-2019, 05:37 AM   #5
hammerweight
What a great write up.....going to print that for future reference as I also have an Eliminator for future migraines!
Thanks Govmule.
Old 11-11-2019, 07:14 AM   #6
john the hat
Thanks all but checked everything mentioned by your good selves but still no go,just does'nt seem to be pulling the gas up ,got me stuffed
Old 11-11-2019, 08:28 PM   #7
hammerweight
This may sound rudimentary, but you do have good fuel flow from the tank?
Plugged filter....collapsed or rotted fuel line?
Lots of fuel in the tank(creating a pressure, somewhat)?
Old 11-11-2019, 08:41 PM   #8
Does the piston slide up and down easily and is the correct oil inside so it dampens the movement and seals it? Do you pull enough vacuum to even make it slide. Have you tried to tickle it by squirting raw gas in side the manifold before a starting attempt?
Old 11-12-2019, 01:29 PM   #9
Rivera's Eliminator II is not supposed to run ANY oil in the damper.
I just looked for my instruction sheet but couldn't find it. I'm certain the instructions that came with min said no oil.
Old 11-12-2019, 02:30 PM   #10
I think they recommend a spritz of WD40.
But the point is a good one... I have run into these where moisture between the alu slide and alu body has oxidized the piston in place.
